Question about HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Firmware
I am trying to install a 128mb memory upgrade into my hp 1320n memory slot. When the memory is installed, all the lights on the panel are flashing, which means that the installation is unsuccessful. How do I get my printer to accept the upgraded memory module? Please Advise. Regards Bogalous
Anonymous
SOURCE:
Anonymous
  • 28 Answers
SOURCE: HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Posted on Feb 22, 2008
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: hp laserjet 1320
well..you may find that driver here, though
Posted on Mar 17, 2008
Anonymous
SOURCE: 1320 not 1320n
These days printers are cheaper than before. Why spend money and buy with no warranty.
I would never buy a printer or a computer second hand (used one) unless it is free.
If you are a business person why mess with the used stuff.
ag
Posted on Oct 25, 2008
Anonymous
SOURCE: Laserjet 1320 will not pick paper
A small plastic 'key' on the end of the paper pickup drive shaft has been known to break off. You will know if this has happened if the paper feed roller rotates freely.
Posted on Nov 05, 2008
Anonymous
SOURCE: HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Posted on Jun 13, 2009
I have 1320n printer but i cannot print in network plz solve
YOUR PRINTER IS NOT SHARED ON THE NETWORK FIRST GO TO THAT COMPUTER WHERE IT IS INSTALLED AND GO TO "PRINTER AND FAX" OPTION RIGHT CLICK ON 1320N PRINTER THEN SELECT PROPERTY THEN SELECT SHARE OPTION AND CHECK THE OPTION "SHARE THIS PRINTER".
Jan 19, 2011 | HP LaserJet 1320 Printer
Laserjet 1320n Will not print
You need to install the 1320 driver on the "new" pc.
Mar 13, 2009 | HP LaserJet 1320 Printer
HP laserjet 1320n keeps printing jetdirect configuration page
Are the proper drivers installed on each system?...Vista will not work properly on XP and vice versa. Make sure they are insttalled correctly
Mar 03, 2009 | HP LaserJet 1320 Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
Hp 1320n cant print jobs simultaneously from different users
You may need to add memory to the printer so it can que the jobs. The memory is very cheap...128MB 100-pin DIMM for HP OEM# C9121A
Or...you could setup a printer server que and let the print server manage the jobs for you instead of having the printer hold the que.
Dec 09, 2008 | HP LaserJet 1320n Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
DRIVER
64 bit drivers can be found here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=410624&prodTypeId=18972&prodSeriesId=410622&swLang=8&taskId=135&swEnvOID=1026
The drivers are specific to AMD and Intel Processors. Make sure you choose the right download link for which proc you have.
Also is it just an hp1320 or is it an 1320N? if its N you will need to tell the driver where on the network it is.
May 02, 2008 | HP LaserJet 1320 Printer
Hp 1320 driver
Go to HP.COM to the drivers and support tab, search for your driver and download
Apr 17, 2008 | HP LaserJet 1320 Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP LaserJet 1320 Printer Logo
1,020 people viewed this question
Ekse
Thomas F. Schneider
