Question about Texas Instruments TI-82 Calculator
How do I open the calculator to change the batteries?:s
I can't open it. I already tried! Somebody help me please:)
Posted by Samantha on
Craig Butler
    President:
  • 1,730 Answers
If there are no small screws on the back to come out, it's a 'clip' type and will need a small thin blade to pry the sides apart to open.
carefully use a knife blade to pry it open.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Nov 13, 2011
HELP! ACT Emergency!
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 08, 2013 | Texas Instruments TI-85 Calculator
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
My TI84 does not respond except for sin
Hi
if you can open the calc and check if you see some spots of liquid or acid that leak from the batter if yes take the main circuit out and clean the contact if it will not help its an hardware failure
this can be fixed let me know if you want to fix
Jun 14, 2012 | Texas Instruments TI-84 Plus Calculator
My Galaxy Mini , just turned off all of the sudden , and won't open again , please help me
try to change battery if you have extra battery...or if you have a multimeter tester try to test if your battery if it is working....maybe your battery is drained..if the battery was drained already you can't charge it by your ordinary charger i mean your indoor charger that you usually use..if that's the case find a universal charger that you can use..it works sometimes..goodluck
May 22, 2012 | Samsung Cell Phones
I've had my ti-86 for a very long time & recently it just quit working. I changed the AAA batteries & the back up battery & it will not come back on. Please help???!!!!
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Dec 02, 2011 | Texas Instruments TI-86 Calculator
All of the sudden it stopt working. Nothing happens when I push the ON button. I changed batteries. I took the backup battery out and put it back in (didn't put new one). Nothing helps. I changed the...
It is sold with an dapator that powers the calculator through the USB port. Use it and you will eliminate any doubt about the batteries. Try resetting the calculator.
Aug 26, 2011 | HP 50g Graphic Calculator
My TI-84 calculator isn't working. When I press the "ON" button, sometimes it would respond, but most of the time it doesn't. The screen just remains blank. I've changed my batteries...
try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same, but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 09, 2011 | Texas Instruments TI-84 Plus Calculator
My screen turns on but when you do anything it has random numbers, line and letters on it and i need to get it fixed immediatley
I've had this issue before with my TI-83 Plus. I'm not sure exactly the solution I used, but these steps progress through the mildest to most extreme methods of fixing the calculator.
Solution 1: Take the batteries out.
Odds are you've tried this already, but it bears mentioning.
With the calculator on, remove the triple A batteries housed in the back. After a few seconds, replace them and turn the calculator on.
Solution 2: Clear the RAM.
Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
Solution 3: Reinstall the operating system
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now"
Here is the website to reinstall your OS. First you'll need the TI-Connect software.
Solution 4: Remove all sources of power. This is a risky move, but if your calculator will absolutely not work after you try even reinstalling the operating system, it might be your last hope.
May 12, 2011 | Texas Instruments TI-83 Plus Calculator
I lost the calculator of nokia 6300? I already update software. How can i again get calculator please say somebody.
Factory restore of the phone. on the menu go to phone options, then security options. Select factory restore. You will be asked for a security code which is 12345 if it was never changed from factory setup.
May 03, 2011 | Nokia Computers & Internet
My TI-83 Plus has a black screen, and changing the contrast and the batteries does not fix the problem.
If you've dropped it recently, there's a chance the screen is messed up. Hitting the back of the calculator firmly may fix the problem, but otherwise there is little you can do to fix the problem other than taking it to somebody who can fix it for you, or buying a new one.
May 02, 2011 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-82 Calculator Logo
124 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
