Question about Marantz Audio Players & Recorders
Flickering TV screen whens streaming Netflix
I have connected my Seagate Free Agent HD Theater+ media player (for streaming Netflix) to my Marantz Pre-Amp via HDMI. I send the signal from the Marantz to my 1080p Samsung TV via HDMI. The TV screen flickers with this setup. When I change the setup pass audio/video via HDMI directly from Seagate to the Samsung the flickering stops but I lose audio quality. I can send audio back from the TV to the Marantz for slightly better audio but this is not ideal. What can I do to get the HDMI feed to the Marantz to work properly?
Posted by Mary Lynch on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: blinking video
You have sent to video output in the menu to auto, change it to the correct setting, should read ntsc.
You also want to check your cabling, if you are using cheap cables that came in the box, throw them in the rubbish and get some good cables. They cost money but are worth every penny.
While checking your cable quality make sure that they are connected properly. Make sure you turn everything off when you are playing around with HDMI cables because they do carry power, and don't like to be unpluged when your system is on.
Posted on Dec 13, 2007
Anonymous
  • 1067 Answers
SOURCE: Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Posted on Jan 23, 2008
Anonymous
  • 1512 Answers
SOURCE: proper connection from amp to pre amp.
Hi Jimmy
The output of the preamp connects to the input of the power-amp, left and right channels respectively. Some preamps (like NAD) can have more than one set of outputs, is this what you are dealing with? If you can give me the make and models of the gear then I can help you more... :)
regards
Graeme
Posted on Feb 16, 2008
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: VIsta Media Center and Comcast Digital
nechmads,
The s video connection is not a digital signal, it is analog.
This should help you get what you need to set it up.
http://www.microsoft.com/windowsxp/using/mce/expert/hdtv.mspx
Posted on Feb 18, 2008
Anonymous
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
Will Netflix work on any TV?
You'll need a device that hosts the Netflix app. This might be a Smart Blu-ray player, or a media streaming box, or a Google Chromecast. I don't know about Charter Cable. Does their box have Apps. Is one of them Netflix?
As long as you have decent broadband speed, and an unlimited service, then running the Netflix app via a host device will work for you.
2helpful
3answers
Can I watch Nexflix on my emerson tv? how do I connect stream movies
1-800-585-7265
  • This service is available 24 hours a day.
Feb 26, 2014 • Netflix
Help me see my Netflix on my TV
Acquire a streaming internet player at a retail store or online. Streaming internet players allow you to stream movies and tv shows from Netflix, videos from YouTube, and music from Pandora, among other options. Different streaming internet players include, but are not limited to:
  • Apple TV
  • Roku
  • Boxee
  • Sony Streaming Player
Plug the player into its outlet. Power it up in order to hook it up with your TV and get it connected to the internet.
Connect your streaming internet player to your TV. There are several different ways to do this:
  • Connect with an HDMI cable. If you have an HDTV, you'll probably want to make use of that sparkling resolution by purchasing an HDMI cable and hooking the cable both into your player and the back of the TV.
  • Connect with a standard A/V cable if you don't have HDTV. Match up the yellow/red/white ports on the back of your TV to the video and audio cables.
Connect to your network. After turning on your streaming internet player, you'll want to connect to the internet. Most streaming internet players nowadays come with wireless internet setup, meaning you don't have to go through the hassle of plugging cables in everywhere in order to get a signal. Simply type in your internet name and password into the guided setup when you turn on your device.
  • If you don't have wireless internet capabilities, you're going to most likely connect one end of an Ethernet cable into the back of your streaming internet player, and the other end into an open Ethernet port on your router.
Finalize your setup. You've got power to your streaming player, you've got it connected to your TV, and you have internet. Consider a few other options before you start watching Netflix from the pleasure of your couch instead of your PC screen.
  • Download any of the latest software offered by the streaming internet player. This could help expedite things and offer cool perks.
  • Choose your video output resolution. Especially helpful for HD nuts.
  • Consider linking the player to your online account, if possible. Some players will use social media to share what you watch with your friends, as well as offering suggestions based on what your friends are watching.
How to see Netflix on my t.v.
  1. Acquire a streaming internet player at a retail store or online. Streaming internet players allow you to stream movies and tv shows from Netflix, videos from YouTube, and music from Pandora, among other options. Different streaming internet players include, but are not limited to:
    • Apple TV
    • Roku
    • Boxee
  2. 2
  3. 3
  4. 4
  5. 5
3helpful
2answers
How to get netflix on tv
Hello
I've the proceedings to get into Netflix on Vizio Tv. But I don'tknow whether I can upload it to you by this site. Let me try. If I fails to do this, and make you understand how to get into netflix with your Vizio TV, please contact me either with [email protected] or [email protected] . I've given you both of my mail ID, because, I don't know whether the newely hoisted Fixya site will allow you to contact me by this old site. If you mail me, please type your need on the subject line of the mail, so that I can detect it faster. I'm engaged with so many problems and answers now. So provide me your need please. Let me copy the document and send it to you by this window. If I fails, contact me. OK.
Managing Your Netflix® Account
In its continuing effort to provide consumers with unlimited content the way they want it, Seagate
is happy to offer instant streamed access to the world's largest directory of movies and TV
programming from Netflix via FreeAgent Theater+â„¢ HD media player. The combination of local
storage and streaming licensed media playback makes the FreeAgent Theater+ a valuable
addition to today's home entertainment."
The following instructions will guide you through how to activate and de-activate access to your
existing Netflix account through your FreeAgent Theater+.
Account Activation
You can view movies and TV shows from Netflix on your media player if you have an existing
Netflix account. (You need a computer with Internet access to create and activate the account on
your media player.)
To create and activate your existing Netflix account on your media player:
If you have any questions or trouble with this service, contact your Seagate representatives:
Siobhan Lyons ([email protected]/408.328.2247)
Nathan Papadopulos ([email protected]/408.328.2167)
Account Activation
your media player.)
I don't know whether this messege can be upload to you. If I fails to do so, contact me. OK.
2answers
Hi, I just pruchased an NBox RMVB HD Media player. I have tried playing movies from my Seagate 1TB hard drive thru the media player on my HD TV but it is unable to read my hard drive however I have played...
you could try formatting your hdd to fat32 also some times this media player has probs reading certain codecs and i also noticed that when a hdd is too full it does tend 2 play up a bit well they say for a hdd to run properly you got to have at leased 15% of free space also there is firmware upgrade out there for the tvd version of this player that works gr8 hope this helped you out ka kite
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
