Cell Phones Logo
Lon Saints Posted on Nov 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When im inserting my micro SD memory card, it appears
My mom borrowed it for a month, so i removed my 1g micro sd memory card. Now im using it again, it keeps on displaying "memory card removed". i inserted another micro sd memory card and has the same problem.
Laxman Bisht
Level 3:
  • Master 662 Answers
  • Posted on Nov 14, 2011
Laxman Bisht
Master
Level 3:
Answers
662
Questions
0
Helped
260252
Points
2514
It seems that the Card validating sensors are damaged. It doesn't seems to be a software problem. You will have to take the device to a repair center and get it fixed.
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
tip
How to unlock /removed password in your memory card
hi,
most of the time we are putting a password in our memory card so that the others cannot view the important and sometimes the confidential files..but unfortunately we forget it so what we are going to do if we cannot open our memory card?if we are going to a cellphone shop we are spending much money ,if we buy a new one we also spend ...
i want to share how to unlock/ removed password in your memory card micro sd...this is applicable only for the card like MINI SD(this is bigger than micro sd and used in nokia phone like n73 ,n80 ) and for MICRO SD (used in nokia E-series ,classic nokia like 3500c ,6300 ,3110c ,7210c etc and other chinaphone )...
tools you need is high end phone like nokia 5800 ,n95 ,e63 ,e71 etc...(for phone using mini sd like n73
you need an adaptor..
here is how..
1. insert your micro sd at nokia 5800 , memory card password will appear just cancel it..
2. go to menu,applications then file manager then you will see that memory card is locked..
3.open memory card you will see memory card locked
4. press options >memory card options and format memory card will appear
5. wait until formatting is finished
6.you will now rename the memory card and the password is gone...
note: in this process all your data will be lost but but you have no choice because no other way to
removed your password than this...
i hope it will help you ,thanks for trusting fixya
on Feb 09, 2011 • Cell Phones
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
1helpful
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
2answers
My nokia 3110c is blinking n switch off after the logo appear
Those who still have this restarting problem on Nokia 3110c ... Im telling the solution again, step by step. It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically. Try this method 1] Remove the battery and Micro SD card 2] wait about 5 minutes 3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD {Don t Format the memory card}
9] Switch On ur Nokia 3110c phone. 10] Now Keep ur free Phone memory space [Not the memory card's free space] between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months.During these time u can 1] Send/receive any file via bluetooth. 2] Enjoy Music,video, GPRS,Yahoo Go .....etc 3] Also u can Update music library anytime.
1helpful
2answers
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
3helpful
How can you import pictures in inbox on cell phone to the microchip SD 2gb inserted in phone?
Micro SD cards for cell phones are now costing less and are holding more memory. 4GB SD cards can hold an estimated 1000 songs, over 13,000 images, or 22 hours of video individually. 2GB memory cards hold roughly half those estimates and 8GB SD cards would hold double. So if your cell phonemag-glass_10x10.gif has a SD card slot learn how to utilize this expandable memory option on your device. Follow these steps and you will soon be enjoying your music, pictures, and video on your phone!
  1. Insert your SD memory card adaptor (with micro SD card inserted) into your SD Card drive on your computer. This should open a "Secure Digital Storage Device" or similar window. If not, go to "My Computer" to locate your SD card and open it.
  2. Step 2 To transfer picture files to your SD memory card, open the folder or file that your pictures are stored on. Simply click and drag a file or multiple files and drop them into your SD Card window or folder. You can also copy a picture and then paste it to the SD Card.
  3. Step 3 To transfer music files to your SD memory card, open your "My Music" folder. Select the folder where you are going to get the music from (Itunes, Yahoo Music...). Click, drag, and drop the files into the SD Card window or copy and paste them in.
  4. Step 4 To transfer video files to your SD memory card, open your "My Videos" folder. Select the folder where you are going to get the video from. Click, drag, and drop the files into the SD Card window or copy and paste them in.
  5. Step 5 Take out the SD memory card adaptor from its drive. Remove the Micro SD card (small chip for your phone) and insert it into the SD Card drive on your Blackberry, IPhone, or other compatible cell phone.
  6. Step 6 Go to your media, picture, or music folder in your cell phonesmag-glass_10x10.gif menu. Select which item you are looking for and your files will appear!
Nov 14, 2009 • Cell Phones
4helpful
5answers
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
1helpful
3answers
My New Micro SD Memory Chip
i need help. i insert my lexar 1gb micro sd memory card into my phone and my phone doesnt show that there is a memory card inserted and i have no idea how to work it on my phone. my phone is a samsung blast.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
