Question about Tappan MGF500PBW Gas Kitchen Range
I have a Tappan 24 - Tappan MGF500PBW Gas Kitchen Range
Posted by Rebecca Bishop on
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan range, will not in oven mode, can jiggle wires and bang ongas valve and get it to lite, but will not fire up after cycling.
Easy fix. Replace the igniter. When the igniter gets weak it takes longer if at all for the bi-metal inside the safety valve to open. I could bore you with the details or show you a video I compiled which explains it: HERE
This page shows how the ignition system works: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2010 | Tappan 24 in. Freestanding Gas Range...
Will gas top flowing if pilot lights go out?
hI no they will stay on you should be able to turn them off
Jan 07, 2010 | Tappan 24 in. Freestanding Gas Range...
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Rough space needed to install 24" built in dishwasher
A 24" dishwasher requires 24" of space between two cabinets.
Dec 07, 2008 | Tappan 18 in. MDR251RE Built-in Dishwasher
Tappan 36 gas range display says door loc how do i unlock
let it stay locked it will open by itself, it is just going through a scanning prossing
Nov 23, 2008 | Tappan 24 in. Freestanding Gas Range...
Igniter "clicking" on its own...
new spark module. Most stoves use a common part.
Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
Tappan MGF500PBW Gas Kitchen Range Logo
78 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
MARLON KELLER
Lee Hodgson
Lee Hodgson
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
