This has only happened recently, always ok before. Have tried another usb but it still doesnt work.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
SOURCE: communication error
http://www.fujifilm.com/products/digital_cameras/s/finepix_s5700/index.html
You can go to this website and download the files you need in your computer in order to download the pictures.
The camera comes with a CD, If you don't have this photo share softwares in your computer, you won't be able to download. Also you can take your camera xd or sd card to a store with photo service and have your pictures on a CD. From the CD you can download to the computer.
Artgirl
SOURCE: uploading pictures from my digital camera onto my computer
everytime i plug my camera in the usb it dosnt want to upload pics?
SOURCE: Can't upload pics to my computer
Try it in a dfferent USB port. The port your are using might be bad.
Rob
SOURCE: Can't upload my pics from D60.
Have you tried turning the camera off, then hooking up the cables, and then turning the camera on?
