Contributor
- Posted on Nov 12, 2011
Re: Rear panel for a mitsibishi montero speacker removel
1Lift the rear seat all the way up and towards the front of the vehicle.
2Remove the five Phillips screws holding the scuff plate at the rear opening of the vehicle. Remove the scuff plate.
3Use a panel tool to pry off two screw covers on the edge of the headliner in the cargo area. Remove the Phillips screws located behind each of the covers.
4Pull the carpet away from the edges of the rear-side panel. Remove four Phillips screws located below the carpet at the bottom of the rear-side panel. Remove the two Phillips screws holding the cargo cover hooks located on the rear-side panel.
5Pry around the bottom and back edges of the rear-side panel and pull the panel out far enough to access the speaker.
6Remove four Phillips screws from the edge of the speaker with a Phillips screwdriver. Pull the speaker out of the door and unplug the wiring harness connected to the back.
