My computer will not start up, it shows the dell screen then goes to black screen with alot of writing starting with , we apologize for the inconvenience, and giving 5 ways to restart the computer then it trys to restart every 30 seconds. I have done a ide drive diagnostics check and it says Primary IDE Drive 0: WDCWD800BB-75HAO - PASS Drive 1: No IDE device Secondary IDE Drive 0: HL-DT-ST RW/DVD GCC-4481B - Diagnostics not supported Drive 1: No IDE device WHAT DOES THIS MEAN AND HOW TO FIX
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart. make sure there are no disks in cd floppy usb drives Test all leads that attach to your hard drive including electrical extensions IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
