Replace the Needle with a new one (part No. PZP1004) . Remove the old Stylus (or Needle) by pulling it downwards gently, and push the new Stylus/needle in place as shown in the below photo.
hope this works for you,
You just need to look at the cartridge and look for the make and model number. Once you have that you can search Google for it and the stylus will also show up.
Depends on the circumstances. Is it only when you play it loud? Air- or room-borne vibrations will feed back through the TT to the speakers. Keep the volume down to avoid it.
If you call the stylus a 'needle', replacing it maybe beyond your capabilities. There are lots of reasons for TT sound to be less than perfect and arbitrarily replacing things can do more harm or introduce new problems. Take it to someone experienced and equipped to evaluate the issue.
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
