Question about Hotpoint Ovens
My hot point oven will not get hot
The fan and light comes on
Posted by lynnshuttlew on
Appliance DoC Ltd
    Habit-Forming:
  • 80 Answers
Could be either the thermostat or the heating element, 9/10 times it is the heating element.
Hope this helps
Posted on Nov 11, 2011
I replaced the element in my belling double oven, it wored for a while but was very hot thought it was the thermostat, now it has no heat at all no light but the fan still works.The top oven and gril has...
Hi.
Replace the temperature probe located in the oven cavity. The probe was initially shorted. That caused temperature runaway with the oven getting too hot. After a while the shorted sensor blew completely staying open all the time. That is resulting in no heat.
If the temperature sensor has already been replaced, then problem is either wiring or oven electronic control. Wiring harness is tested checking continuity between different points.
Regards.
Ginko
Jul 17, 2011 | Belling XOU592 / XOU593 Electric Double...
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Main oven does not get hot the fan work and all the lights come on but none of the ements heat up
You need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Nov 22, 2010 | Neff U1661 Double circotherm super...
I used the oven at 425C for about 30 minutes, turned it off, took the food out, left the door open (the fan and light was on. During dinner, we smelled a strong chemical smell, like melting plastic or hot...
your mostlikley correct on the buring wires. The only thing that can be done at this point is to unplug the machine and start tearing in to it to find the bad wires.
Jan 08, 2010 | Whirlpool RBS275PD Electric Single Oven
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
70 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
