Question about Imation Products - imation - Clip Flash Drive, 8GB - Sold As 1 Each - Carabiner clip. - Simple to tr... Hard Drive
I have an 8gb imation that become 4mb free space why it happen?
Posted by ronilo garces on
Brian Sullivan
  • Imation Master
  • 27,725 Answers
Click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your usb drive select format
(note formatting will remove all data on your drive)
then right click on your imation drive select properties you will seea mmount of space used and ammount of free space
hope this helps you
Posted on Nov 13, 2011
  • 2 more comments
  • johngareth_g
    johngareth_g Jan 27, 2012
    this did not help me recover my 8gb USB.
  • Brian Sullivan
    Brian Sullivan Jan 27, 2012
    have you formatted your 8 gb usb drive doing a format willl remove all data on your
    8 gb drive an give you back your space
    click start click on computer to open you should see all of your drives
    right click on your 8 gb usb drive select format
  • Brian Sullivan
    depending on your operating system if you right click on your 8gb drive select properties you will see an array of options select the customise option then select restore default
  • raazesh_77
    raazesh_77 Mar 28, 2013
    these solutions are toooooo general...i expect special silution...i already checked that.
Pendrive 8gb but display 4mb how recovery space
Using Drive Manager repartition and format the drive.
2helpful
2answers
Usb storage size went down from 8gb to 4mb
First, download this Toshiba flash drive format tool
http://softadvice.informer.com/Toshiba_Usb_Flash_Drive_Format_Tool.html
and use to format your pen drive again with this software.
2helpful
2answers
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Please free 4mb
hello sir
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Profiling requires 4mb free space
Straiten the end of a paperclip and push it into the reset hole on the back. When you turn it on, it should operate as normal without any data loss.
2helpful
2answers
Found a small pinhole on the back of the device. In small lettering it says reset. Carefully insert a pin and light push when you feel it's hit a dead end. It resets the issue and you can resume using your device. Leave it up to a girl to find that and figure it out. lol
I have the same problem, and the RCA website is a piece of ****.
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Imation Products - imation - Clip Flash Drive, 8GB - Sold As 1 Each - Carabiner clip. - Simple to tr... Hard Drive Logo
Top Imation Computers & Internet Experts
Raj Patel
Mehandi Husain ...
ray gallant
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
