When I turn on my SONY KDS-50A2000 TV, the power LED blinks green a few times,then the power LED light blinks RED four times, there is a wait of few seconds, and then it blinks red four times again, the TV does not turn off until I pull out the power plug. SONY customer service suggested that the cooling fan needs replacement.
SOURCE: KDS 50A2000 red lamp light blinking 2 times
Did you use an original Sony lamp? If so, I would say that the problem lies with your lamp ballast, or lamp power supply. Also, keep in mind that, although rare, occasionally the lamp power supply will fail in such a way that it will take out the lamp and any other lamp that is put in. So if your new lamp is blown, it is likely the lamp power supply that is at fault and you will require a new lamp as well.
SOURCE: sony kds 50a2000 power light blinking
Your lamp has blown. You can order the lamp from Sony and replace it yourself. You can purchase the lamp here:
http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Other vendors also sell this lamp at a cheaper price (check the net)
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
SOURCE: Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
