How do i block or restrict some websites on my network so that some machines wont access it e.g facebook. Am using ADSL Connection with TP Link TD WD8901G wireless router and Cell Pipe residential gateways.....please help
SOURCE: i have ADSL wirless TP LINK TD-W8920G v1
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
SOURCE: can tp link W8901G be
The TP-Link W8901G wireless router can be used anywhere where 110V AC (Alternating Current) is available, i.e., not in Norway, where 220V is the normal, and not in the Sahara Desert (unless you have a reallllllllllllllllllllllllllllllllllllllllllllllllllllllly long extension cord).
SOURCE: My ps3 won't connect to
Try connecting the PS3 to the router via ethernet cable, their may be some buttons with numbers on the back of your router, one the PS3 is connected press one of these.
the PS3 should know the paired with the router and the wireless should work.
hope this helps!
SOURCE: My tp-link TD-W8950ND 150Mbps Wireless Lite
this is because your modem is out dated your better off getting a new one
SOURCE: Need help! Cannot access YAHOO
try power cycle by removing the power of the router for one minute then plug it again.
check the cable if all of it tightly connected to the specified port
if it is a modem router it should have a 3 cable connected to it
Phone line, Ethernet cable and the power adapter.
the Ethernet cable should be connect to the back of your tower( computer).
check you phone for a dial tone.
check the light in the router like dsl , ethernet ,internet and activity.
all of these must have a light.
