CMOS Clear moved the jumper now it resets every time it is turned off
To reset the CMOS the easiest way is, remove the motherboard
battery for ten minute then install it again. It will clear the CMOS. Then reset
the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS
Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
Almost all motherboards use a small coin sized CMOS battery to store
all BIOS settings along with the password. To reset the password, unplug
the PC, open the cabinet and remove the CMOS battery for approx. 15-30
minutes and then put it back. It'll reset all BIOS settings as well as
the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the
Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS
settings along with the BIOS password. The location of this jumper
varies depending upon the motherboard brand. You should read your
motherboard manual to check its location. If you don't have the manual
then look for the jumpers near the CMOS battery. Most of the
manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
