Question about Activision Video Game Consoles & Games
Procedure to sync rapalla to 360 xbox
How do I sync my fishing rod to my 360 xbox, so that I can go fishing? I have pushed the little button above the large button facing you.....the rotating green goes faster---then slows down but does not stop. I am new to xbox 360,,,,but would like to go fishing......ps. hand controller works the game fine. Cheers ..Des
Posted by DESMOND BLACK on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Multiplayer mode Kung Fu Panda pc game
The xbox 360 wirless controller has very little lag that you would not be able to notice i would suggest just getting the controller and if u want u can also get a xbox 360 controller that is wired.
Posted on Jan 12, 2009
Anonymous
  • 3 Answers
SOURCE: xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Posted on Feb 23, 2009
Anonymous
  • 26 Answers
SOURCE: Guitar with slider for Guitar Hero will not sync...
Sorry. Cant help you. Maybe go to GameStop?
Posted on Mar 06, 2009
Anonymous
  • 152 Answers
SOURCE: Syncing problem? Xbox 360
Is your TV a HD TV? Be sure to go to options and synchronize the game. There are delays with HD TV's and the GH/Rock Band games.
Also, try using a wired guitar to see if there is a problem with the wireless guitar you are using.
Hope this helps!
Posted on Apr 06, 2009
Espen
  • 15 Answers
SOURCE: Guitar not working for Xbox Guitar Hero
This got to be a hardware failure with the guitar, there is no wires or some button you pressed by mistake.
Try checking out that cables are plugged in, try to switch USB port to connect on the xbox 360, or else its a hardware problem.
Posted on Apr 13, 2009
How to turn on the xbox 360 wireless fishing rod
I just tested it by turning off the Xbox, I then plugged in the fishing rod, and pushed the on the button on the Xbox, with another game disc in the Xbox........The Xbox started up fine, I navigated the profile menus, logged on and went to the game menu, and it all worked fine, except I did not play the game, because it would be too strange to play with the way the button is set up on the fishing rod. I imagine I could get used to it if there was a good reason but anyway .yes the controller will work on other games if you wanted to get used to it. Regards, Toshiba Support
Toshiba Support Number 1 800 505 1746 Toshiba Customer Service
Oct 10, 2018 | The Video Game Consoles & Games
Cannot get my xbox360 and rapala rod to connect wirelessly
1. Ensure Batteries are good.
2. Review the "xbox360 Controller sync procedure" on YouTube.
3. Find the sync button on the Rapala Rod. (small white button) Push it and push the controller sync button on the console.
Dec 23, 2013 | Microsoft Xbox 360 Console
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
I cannot use my fishing rod with the x box 360 slim black box that comes with the kinect. What button do I press for it to recognize the fishing rod and not the controller that comes with the...
f***thet i have the same problem.i just hade 2days ago the same game4the same xbox.n i dont know how to conect it.did u solv it jet?can u let me know what 2do?plz thx
Feb 13, 2011 | Activision Rapala Pro Bass Fishing for...
My xbox 360 wireless controller is new and the green light just keeps falshing it will not go on to 1 or 2 player.
you may have to sync your controller to your xbox. First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the sync button on the 360 controller so the lights around the big X are spinning around. you will find it located at the top of your control close tp LB (it has 3 little waves next to it) Finally, push the sync button on the 360( which is located directly to the right of memory unit B or with xbox360 s nex to the part at the front with 2 usb ports) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Wireless Controller
I just Bought this Xbox 360 but I Can't get it to turn on it comes on green but nothing happens.Do I have to have a internet connetion to play the games that I bought? or is there something that I did...
Ok have you taken the current disk out of your XBOX and then close the tray and let it read nothing! It kinda has to reset itself because of a previous game you were playing. So once you do that put your Modern Warfare in and you should be good
Feb 14, 2010 | Microsoft Xbox 360 Console
Im trying to find out how to use controllers on a another xbox my boy only has 1 control so i bought mine it doesent seem to work how do i get it set
You have to sync the controller. Push the sync button that is inline with or located right next to the memory card slots on the front of your XBox. When you push this button, the ring of lights will spin. At this time push the small button on the top of your controller and the Xbox Guide button light will spin as well. You are now synced.
Dec 25, 2009 | Microsoft Xbox 360 Controller
Xbox 360 rock band
no batteries, thats why theres a wire. you only need to resync wireless controllers. its the little button under the memory card slot on your 360 push that then the little button on the side of the guitar to sync.
Jul 31, 2008 | MTV Games Rock Band Bundle for Xbox 360
I need the instructions for syncing the guitar to the xbox 360 console
You'll need to find the sync button on the guitar, and then hit the sync button on the 360 (next to the black bar sensor thingymajig). They'll start flashing and eventually connect.
The sync button on the xbox is right beside the 2nd controller slot lol And the button on the guitar is beside the Mic slot. But first u have to push the xbox button on the guitar
Jan 06, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
98 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
