Question about Apple iPhone 3G
I DON'T KNOW HOW TO DELETE MUSIC ON MY IPHONE 3G
Posted by JENNIFER M. BALITE on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
You can delete music manually within Music app or resort to the 3rd-party tool to handle deletion task in batch. Just follow the below steps to do that.
Tutorial for Deleting Music from iPod via Leawo iTransfer
Step 1. Run Leawo iTransfer and connect iPod to computer with USB cable. The software will recognize and detect your iPod.
Step 2. Click the name of iPod and choose Music in the left sidebar. The iPod music will display in the right part of the software window.
Step 3. Hold Ctrl/Shift key to select the songs you want to delete, and click the Delete button at the top middle. Or check the square checkbox beside Name to select all songs, and then click the Delete button.
Step 4. After clicking the Delete button, you'll see a pop-up dialog. Click Yes in the pop-up dialog to start deleting music from iPod.
For more details, check: Top Three Ways to Delete Music from iPod/iPod touch
Posted on Sep 16, 2019
Michael J.
  • 443 Answers
ITunes.
Go to your iTunes library of music. UNCHECK the songs you don't want from that list. Then resync the phone and it'll remove all that you unchecked from the phone...
Confusing and over complicated, yes. But the list on iTunes is the list in the phone. So what ever you check or uncheck is whats on or off the phone
Posted on Nov 11, 2011
How can you delete iphone apps if you don't use them ever?
You May choose to connect with itune and delete all apps required else double click on app and click delete.
Not so tough Job. Hope it helps
Apr 01, 2013 | Apple iPhone 3G
Iphone 3g camera will not work. get message saying not enough storage
You don't have enough storage space on your Iphone. In order to take more pictures you must delete some stuff to free up your storage. Depending on what you have on your iPhone, you can delete apps, music, photos, videos...etc. This will all give you more space. If you click settings>general it will give you an idea of whats taking up so much room.
Oct 21, 2012 | Apple iPhone Smartphone
How can i delete song from ipod on the iphone
You inside, build a itunes ipad play lists, the need to join the songs, and then in the LIST are issued in select ipad manual sync ipad play lists. Don't want to play the song from the list, then sync it cancelled. Remember, all operations are in ITUNES music repository, not in the IPAD music repository. Manual sync only it in IPAD inside
Sep 09, 2011 | Apple iPhone 3G
How to download music on a iphone 3g?
there are several ways you can download and put music on your iPhone 3G
1.-Purchase songs in iTunes directly on your iPhone (this will cost you money and require you to create an iTunes account,if you download apps, you already have one).
2.-Insert a CD into the computer you plug your iPhone to, open the CD with iTunes, and rip the contents of the disc into iTunes (iTunes has a tutorial for this if you need further information), sync your phone with your iTunes on the computer and the songs will be added to your song library in your phone.
3.-You can use a P2P (peer to peer) sharing program ex. Frostwire, Winamp, eMule, to download the songs onto your computer. Take note of what folder these downloaded songs are being sent to. In iTunes, select File>add folder to library, a window will open, select the file where the downloaded music is located, and iTunes will add it into the music library in iTunes. Sync your phone with iTunes and the downloaded songs will be added to the music library on your phone
Jul 01, 2011 | Apple iPhone 3G
My iPhone stop ringing. It only vibrares. Also the keyboard does not sounds. However I can listen to the radio . What can I do? Thanks a lot. Dolores
Chances are, you turned ON the Silent switch on the side of the iPhone. You'll know that it's turned ON if you see a little red dot (for iPhone 3G & 3GS) or a red line (for iPhone 4). To locate it, refer to the image below: 16aae05.jpg
CLICK HERE if you don't see the image.
For more iPhone tips and tricks, CLICK HERE.
Did this helped you?
Jun 03, 2011 | Apple iPhone 3G
How do you delete songs off of an Iphone
The easiest way is to open iTunes on your computer, and delete the song from iTunes.
Next, sync your phone. This will remove the song from your phone
Dec 29, 2010 | Apple iPhone 3G
How do i delete songs from an Iphone 3gs
1.Go to Settings
2. Go to General
3. Go to Usage
4. Wait for Storage to load
5. Go to Music and swipe
6. Delete will pop up
7. Press Delete
This will delete ALL songs, but will not remove the music app.
There you go.
How to Delete Songs from iPhone
iPhone Data Eraser Clean up Data Safeguard for Ultimate Privacy...
Oct 25, 2010 | Apple iPhone 3G Black Smartphone
How to delete songs from the phone
That's easy. Do the following steps:
1. Plug your iPhone to your computer.
2. Open iTunes from your computer.
3. Select you iPhone under the devices menu.
... If you take a closer look at the first image, on the "Options", this is what you'll see: be39a77.jpg
4. In my case, I sync my entire music library, so if I want to delete a certain song from my iPhone, I just uncheck it from my iTunes music library before I sync. If we have the same case, then you just have to go to your music library (which is the top selection from the sidebar)...
... and uncheck the songs that you want to delete from your iPhone.
But when you sescted the other option - Manually manage music and videos, click on the triangle before youre device's name.
Now, select "Music", under your iPhone's name and right click on the song you want to delete, then select delete.
Hope this helps.
For more iPhone and iPod touch tips, click here.
Feb 10, 2010 | Apple iPhone 3G
Deleting songs from iphone
you should be able to go into itunes and delete the songs, then sync your iphone again. If that doesn't help then I would go into the apple store and see why not. you can also just call apple for support for free if you are an at&t subscriber good luck
Apr 05, 2009 | Apple iPhone 3G
IPhone 3G manual
how i download music in my new iphone
Jul 24, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
167 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
