Teac AG-D9100 Receiver Logo
Anonymous Posted on Nov 11, 2011
The word PROTECTin display
My receiver works great and the suddenly quits and the word PROTECT comes up in the display.If I turn it off it usually starts right back.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Nov 11, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767303
Points
24828
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
How to remove protect from my cd receiver display, model HCD-EC99i?
When the protect indicator comes on, usually a power transistor has blown. The unit needs to be taken to a repair shop.
Reset receiver
If it's in protect mode that usually means a fault in the audio power output stage(s) Must likely a shorted output device,Some receivers have intergrated circuit outputs that may be the problem, you need pro.help these problems can be quite hard to troubleshoot if you don't find all the problems any new parts you install can turn to junk in the blink of an eye(or less).
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
3helpful
What does the word "Protect" mean in the display? My receiver AG-D9100 works great and then quits and the word PROTECT comes up in the display. If I turn it off it usually starts right back up ok...for...
Something is shorting out and tripping a safety feature that protects the amplifier from damage.
try a few simple steps to see if the problem is internal or external.
First make sure that none of the speaker terminals have any loose strands of wire that could be grounding out the terminal and that no wires from the red terminals are touching the component or the black terminals / wires.
secondly disconnect all but one speaker test it to see if t causes the amp to go into protect do so for the other speakers until one trips the protect mode. If one of the speakers is tripping the protect mode it could be a damaged / blown component.
just for fun make sure your speakers are 8 ohms this can be found on the manufacturers website or in your manual. Its rare but some speakers are 4 ohm and they can cause amplifier issues such as tripping a protect mode.
You may have to evaluate the "value" of the receiver and determine if its worth repairing. Many shops will charge a "diagnostic" fee which may be $40 to $80 and remember that parts and an hours labor may not make good financial sense especially if you are talking a unit that is 5+ years old.
Hope this helps
1helpful
2answers
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
2helpful
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
2answers
It works a few minites,then stops and displays "Protect".
Your complaint isn't a problem at all. This is a usual characteristic of the relevant amplifier. The protection mode comes on when the main volume/bass/treble or whatever is too loud. Unfotunately, you can not overcome it. But, as they always say: It's a Sony:)
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
