Question about Mitsubishi WS-55511 55" Rear Projection Television
How do i reset my mitsubishi television model#ws-55511
Posted by jesus antonio zayas on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
First a reset may not help unless I know what your problem is.
If model listed (WS-55511) IS CORRECT: set has 3 hidden menus:
Option Menu (hard reset of all settings to factory)
Technical Menu (Adjustments for various things)
Convergence Menu for adjusting convergence.
THESE ARE NOT ACCESSED FROM CUSTOMER MENU. Each requires Mitsubishi remote and a 4 digit code .......
So, What is your issue with the set?
I have the codes but it depends on model number and what problem with set is, reset is in Option menu but will not cure all problems.
SD TECH
Posted on Nov 11, 2011
5 Related Answers
SD Tech
SD Tech
  • 14553 Answers
SOURCE: WS-55511 Mitsubishi projection TV is stuck on INPUT 4.
This model was first made in 2002 and is a V21 Mitsubishi chassis.
I presume the front input or device button does not do anything.
This (if it is a WS-55511) has an option code that can be accessed. It will reset everything back to the condition the set was in when it was new in the box; once executed you will have to put it in the cable band and autoprogram it----email me if you need instructions for this and I will give them to you.
[email protected]
If this was helpful I would appreciate a vote from you.
Posted on Aug 12, 2009
Vista Electronics
  • 1694 Answers
SOURCE: Mitsubishi television
!-800-553-7278 Mits parts line,however,could we go over the symptoms before you order an expensive part??? Then I will
be able to direct you.....T.
Posted on Oct 20, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking on and off. We've used the paperclip to reset the machine and it doesn't work, and we've unplugged the power supply
replace the capacitors on the DM board. Heres a link to the repair kit which contains the replacement capacitors and instrucions of how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on May 11, 2009
asnowman
John Snow
  • 788 Answers
SOURCE: Mitsubishi WS-55511 Rear Projection TV
Your symptom sounds like at least one damaged convergence IC.
On Mitsubishi's2.gif you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend replacing them both at the same time because the chips legs can fall off due to the heat of the IC. If you have a good low wattage soldering iron ~ 45W (available at radio shack) you can perform the repair yourself, and this will most likely take care of the entire issue.
I like to remove the board that the IC’s are on so that I can unsolder the connections and clean then up using solder wick (this is also available from radio shack). Removing the board is not a real issue as the connectors are all labeled with an alpha number, so that you can connect them back real easy. There are three in the middle towards the front that I like to mark with a sharpie as they are the red green and blue convergence coil connections (they are all the same size in a row). Just mark them with slashes, like I, II, III, or something like that. If you mix them up it is not a big issue, you can test swapping them around until the picture lines up.
Please be sure to remove the entire white heat sink compound on the heat sink and apply an even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00, and sometimes more depending on your area.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact
Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10.00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in
California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 21, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Mitsubishi HDTV 1080, model WS-55511. Color
Yes, it can be repaired, replace convergence out chips (two ICs) on main board.
If you are not comfortable with TV repair or have no experience, call local tech to fix it. Cost of repair would be $180 or so.
Posted on Nov 11, 2009
Tip
Mitsubishi WS-65712 Manual Download
Download Mitsubishi WS-65712 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65712 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65712 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Bypass Mitsubishi WS-65712 Front Lock
Reset Mitsubishi WS-65712 VChip Password
on May 05, 2010 | Mitsubishi WS-65712 65" Rear Projection...
Tip
Mitsubishi WS-65711 Manual Download
Download Mitsubishi WS-65711 HDTV Manual
Have you misplaced your Mitsubishi WS-65711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65711 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-65711 VChip Password
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Mitsubishi WS-65611 Manual Download
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-65611 VChip Password
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Mitsubishi WS-65511 Manual Download
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-65511 VChip Password
Bypass Mitsubishi WS-65511 Front Lock
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Mitsubishi WS-55711 Manual Download
Download Mitsubishi WS-48511 HDTV Manual
Have you misplaced your Mitsubishi WS-55711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55711 HDTV Users Guide?
I hope that helps.
Reset Mitsubishi WS-55711 VChip Password
Bypass Mitsubishi WS-55711 Front Lock
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-55511 55" Rear Projection Television Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
