Question about Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox 37 lcd wont' turn on
Model number us 37MF337B/37 I took of the back cover and was trying to find a burned out chip. nothing stood out. So I removed the cable line from the power supply and the video board when the lcd screen came on. My question is do your think I have a bad power supply board. or is it the video board with the tuner? Thanks for any help
Posted by Dan Martinez on
5 Related Answers
Anonymous
SOURCE: Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Posted on Jul 09, 2008
Abcd
  • 70 Answers
SOURCE: Philips Magnavox 37" LCD Flat
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Posted on Jul 07, 2009
Anonymous
  • 4 Answers
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Posted on Sep 11, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: Model 37M32ID/37 magnavox LCD.
I think that is the wrong fuse but still it would pop if you have a line problem on the circuit that fuse is piping for a reason not the value but there are more issues on the circuit then what you repaired I would start digging and see if there are more popped caps! not in the power supply but else where like the hd push board or the decoder in better terms.
Thanks hope this helps if you cannot get it done take it in for a estimate as estimate will tell you the issue fixed or not and you can take that advice from that tech and repair your TV!!
Please do click the accept button if you like my advise.
May i suggest a service manual?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 19, 2009
Testimonial: "rulds2008 provided good and timely information and advice. I appreciate the quick turn around."
Buddy Mcsparrin
  • 1684 Answers
SOURCE: What is the part number for the Magnavox LCD TV 37MF331D, power supply
The part number for the power supply board in the 37MF331D TV is actually 715T2056-1 If your TV is not turning on you should be able to repair your power supply board for much less than you can buy a new board. The most common problem with these boards that causes the TV to not power up right is a failure of the filter capacitors. You can get information on what parts need to be replaced at this link:
http://www.ccl-la.com/catalog/product_info.php?products_id=216
I hope this helps,
BuddyMc
Posted on Sep 24, 2012
How to fix my magnavox LCD tv, the picture went out, have sound
Hi Daryl,
This is a common problem with LCD TVs. Back light failure is the cause in most of the cases. I do not think you can do anything about it yourself. Please consult a local TV tech.
Good Luck
Magnavox turns on then goes off model 37f337b/37f437b
More than likely power board,usually repairable,look for blown capacitors.A blown capacitor will look like the top is rounded also suspect capacitors will show signs of the plastic coating shrinking .
Popping in speakers then lines through picture sometimes no sound
Likely bad audio output circuit---it will usually be part of the main board in these sets----not likely to be a do it yourself repair.
Sometimes when I turn on my Magnavox 37MF337B tv it emits a very loud squeal and the picture/channel locks up. I cannot turn it off with the remote. I have to unplug it and try again. When it is on though...
you have some bad caps in the mainboard very common on this model the can shaped devices will have a puffed up top i would suggest you have a tech reaplce them they are hard to get out due to the large ground plain on the board you need a good hot iron
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Magnavox 37MF337B/37 Speaker Problems
It needs a small signal board, it is still under warinty, up 1 year after you but it, look in your manuel, or on line for there phone number call them, asap, they should set you up with a service center, and they will cover part and labor
Toymax Magnavox 37MF337B 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
