I need to find out if what type of memory belongs on this motherboard, because the two I put in are must not be compatible because it still runs slow.
The memory that can be be use is DDR1 400mghz and can be expanded to 4gb.
For more detail of the specs, go to this site................ http://support.gateway.com/s/PC/R/1008835/1008835sp3.shtml
Hope that helps!
Ooops!
Just found out that ur Mother Board is a Pentium 3!
It uses a PC100 memory card for the early type and DDr1 for the later type.
If you see two guide slot on the memrory rail, it means it uses a PC100, 133mghz.
If you see a single guide slot on the memory rail, that means it uses DDR1, 400mhz.
Hope that clarifies everything!
If the problem is the speed of your computer.
My advice is to upgrade the motherboard to Pentium4 or the latest version of dual core.
Hope that helps!
This model has two version, the early type uses DDR1 and the later have used the DDR2.
First/early PiN type of dual cores...
ok i went to the support site that u show n it did not show the same motherboard 4000676. Did I look at it wrong? Another thing also u said that it uses ddr1 or ddr2, on one of my computers I have example ddr2 PC2700 what are those numbers does it matter or just the ddr. Whats dimm because when i looked at the motherboard it look like it had that by the middle slot. I really appreciate ur time/effort to help an old lady like myself figure this out. Thanks in advance.
The numbers that you see in mghz is the speed.....
