Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
HP PSC 1610 All-In-One Envelope jams
When I first got the machine - envelopes would feed - no problem - over time - with use - paper feeds fine BUT envelopes jam 3 to 1 - does something need to be cleaned?? is there something I can do? It's very frustrating and time consuming to clear jam after jam and ruin 3 envelopes to get one printed correctly....can you help me?
Posted by sgtexas on
  • me383 Mar 07, 2009
    Have had exactly the same problem with the same printer, and it developed in the same way.
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: HP 4L Envelope Feed Problem
check the internal roller ( central ) easy to remove . clean with alcohol's dry put it back ... (robber couvred)
Posted on Mar 13, 2008
Anonymous
  • 214 Answers
SOURCE: envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Posted on Apr 24, 2009
Anonymous
SOURCE: won't feed paper
I had the same problem it was not feeding paper, and was giving the out of paper msg, I checked and the feed roller ( small black one in contact with paper) was not rotating, Also when the back cover is removed the roller also did not rotate. I took apart the printer and found that a white gear with the encoder disc (clear film with printed lines) on the central shaft was slighty broken, The shaft is knurled but is a poor design. I had to drill through the gear and the shaft to fit a pin to be able to fully secure the gear to the shaft. Kevin
Posted on Jun 09, 2009
Anonymous
  • 70 Answers
SOURCE: I'm trying to print envelopes with my hp psc 1315
I would recommend you re-orientate your envelope going into the printer by placing it flap up, right flush but with the widest side in fist (or horizontally as per your description). Below is my attempt of the envelope as it should be placed in the paper tray (all in bold characters): _________ |\ /| | \ / | | `...' | |__/___\__|In your document editor it should be orientated like a normal document.Best luck,Ed(In case the drawing is not very clear, click here an the way to put the envelope IN the aper tray should be like the 1st drawing)
Posted on Nov 22, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: HP PSC 1610 - Keep getting paper jam error with no paper jam.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 09, 2010
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Paper feed will not stop
I suggest You Go to Official HP Printer Page For You HP Printer Problem On Below HP forum URL Link: Out of Paper Error Message and the Printer Does Not Pick Up or Feed... In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :http://www.techsupportprinter.com/hp/
1helpful
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
8helpful
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
1helpful
2answers
Envelopes get jammed Is there an upper tray? Word tells me in envelope printing set up that I should be feeding envelopes from upper tray face up for my printer model.
I had lots more problems with envelopes until I made sure to adjust the guides on the left over to where they touch the envelopes.
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
2answers
Envelopes jam in my hp 6940; paper sheets feed fine
Envelope printing
I have an older, but similar, 5510 model with the same problem. A partial solution that works about 75% of the time is to tuck the envelope flap inside the envelope and give the end of the envelope that is to feed into the machine a slight curve by gentlly bending it on both sides. Then make sure there are only a few sheets of paper in the paper tray (less than 1/8" thick stack). Position the envelope so it is only about 1/2" from the end of the paper in the tray so the feed rollers have to transport it into the machine. I also have to set the margin for the return address in Word to be 1" from the edge of the paper so it prints in proper position, but this may be a problem with my Word 2000.
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
1helpful
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
Ben Johnson
Marvin
Marvin
