Question about Fuji Cameras
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my camera wont come on it shut down with the lens still popped out. i keep pressing the power button and nothing is happening except the screen act like it wants to come on but it wont
Posted by kelly merriweather on
Daniel Bakewell
  • 691 Answers
Remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Posted on Nov 09, 2011
Olympus Stylus Tough 6000 won't upload new pics
Perhaps I can help????
I don't know how many pictures you already took, but perhaps you did more than 10000? Your camera can shoot pictures in one directory, with numbers 0001 till 9999. When it reached 9999, it will automatically make a new directory and start over with number 0001. Not sure if that happened, but you could look for another directory on your memory card.
Then I do have a question. Do you mind what happens with your pictures when your camera dies? Because I think that is the only place you have all your pictures. (I hope I'm wrong) Or worse what if you lose your camera? Or did you already make backups from your pictures?
Try to make it an habit to backup all your pictures shortly after you took them. And one backup is none backup. At least two backups on 2 different media. Like one backup on your computer, one on an external hard disk, memory stick or DVD.
Jan 10, 2014 | Cameras
Trying to save my pic's to my computer , but when i plug the usb cord into the computer nothing happens and i can't seem to be able to find a way to start it up in my start up menu, can you explain...
Open "my computer" and then plug in the camera. Turn it on. A removable drive should appear on the screen. Double-click that and your picture files should appear. You can then drag and drop them into "my pictures" or into a folder you create on your desktop.
Sep 21, 2011 | Pentax Optio 30 Digital Camera
I plugged it to my computer with a usb cable and was viewing my pics to import, then i accidentally unplugged my camera from the usb cable..now it wont turn on and the lens is still out...no power
Try to keep pushing the MENU task at the same time with power task. For some models it work. I`m not sure 100% it will work for your model to , but is worth to try.
Jan 26, 2010 | Nikon COOLPIX S570 Digital Camera
Cannot download pic.s from camers to pc.
I would remove the memory card and use that to transfer the media to your pc.... I can't tell you why it is not showing up on any of the pc's. The only thing I can think of is possibly the usb cord is bad or that vivicam has special software you need to download. But you can definately get the media onto to your pc by bypassing the usb cord and remove the media from the card and place it in a folder on your pc .. hope this helps... good luck
Oct 19, 2009 | Cameras
Downloading pics from camera to computer
This is an easy fix. Be sure your camera to wire and computer to wire connections are good ones. Turn on your camera. If you don't see action on the screen go to the control panel and click on "hardware and sound" then on "view scanners and cameras" Now you should be up and running. enjoy.
May 23, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Pc will not recognize that the camera is connected
Apr 04, 2009 | Fuji FinePix S5100 Digital Camera
My camera was a waste of money if i cant load the pictures i take onto my computer
i have the same camera..when it does that,your computer should be searching for new hardware so you can view your pictures. depending on what you use to view your photos(e.g. kodak easyshare,is where you will view the pictures you have taken prior to plugging in the camera.If there is nothing to view you then its obvious you have taken no pics.
Jul 15, 2008 | Cameras
I cannot upload pics from my camera to my pc.
hi
if you ave the camera's installation cd try reinstalling it
if nothing happens try my computer you may find it under removable drive if it still does not work and ur pics has been saved on a memory card try using a card reader to access the file on it
Mar 31, 2008 | Samsung Digimax V800 Digital Camera
Samsung s630
If you're a MAC user, you could still download pictures from your camera to PC.
No need for you to install any CD software because your camera will be recognized automatically as a removable disk.
Just try to make sure that you'll be using the USB cable supplied in the package and your PC does have good working USB ports.
For transferring pictures with OS (MAC):
- Turn off camera
- Plug USB cable to camera and PC
- Turn on camera
- Connect to computer or printer will come out on camera screen
- Select the desired one
- Press MENU/OK
- "New Hardware Found" will be seen on the right lower corner
- A window will pop out with various options
- Example: "Open to View Files", "Copt to a folder"...
* If nothing like those mentioned above happened,
Double check through Computer Devices with Removable storage:
- Look for DCIM folder in any of the Removable storage
- Select 100sscam folder inside DCIM folder
- Upon opening, all pictures will be viewed
Make sure to check your MAC System for the following:
- Power Mac G3 or later
- Mac OS 9.2~10.3
- Minimum 64MB RAM
- 110MB of available hard-disk space
Jan 05, 2008 | Samsung Digimax S630 Digital Camera
Cameras Logo
59 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
