My printer just keeps sending paper straight threw in stead of printing
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
