My tv is not turning on. we just moved from one house to another
did the move disturb it
you need to take the front panal off to look and see if all three sockets on ctr tubes are seated all the way. the front panal is the one with the power button,vol and ch buttons and aud/vid hook up. first remove the shiny screws from the back on the sides of tv where speaker grils are. remove the speaker grills. then you have four black screws two on each side of panal and two shiney ones on top of panal. remove all six then remove panal careful not to pull too hard on wires. then making sure tv is unpluged, reach in and under the three tube assembelys, push up under the circut boards right center of where the scoket connects to the tube and make sure they are seated all the way. doesnt take much pressure to push on them so dont kill them. also be careful not to do it off center of the board or board or worse the tube will break. if all is well there, you will have to remove more panals and look a little farther for somthing lose or broken. good luck.
