Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
I got 2 twelve inch jl w6v2 with the alpine PDX 1.1000 i accidentally broke one of my RCA's in the amp when i needed to take it out of my trunk. i went and took the amp apart and popped out the end of the RCA. well when i had it apart, the "ribbon" popped out of the amp, not the lid. well i put it back in and then eventually hooked everything back up the same way i had everything before. now i get the amp to turn on with the blue lite on one side and red on the other. any ideas on what i did wrong. i know some stuff about this stuff but please break it down barney for me so i understand. thanks
Posted by Andrew Gardner on
1 Related Answer
Anonymous
  • 156 Answers
SOURCE: ALPINE PDX 1.1000
well you would have to look into the ohms of the amp compared to the ohms of the speaker. If the ohms are different you would have to hook them up in a different way. check the RMS on the speaker as well as the amp, this can also be sufficed by wiring it different if ohms match up properly! Hope this helps you out and if this is not the case let me know.
Posted on Feb 28, 2009
Altanator noise coming out speakers
this usually means you have a power wire or a wire that has power running through it ran too close to your RCA wires or speaker wires and it's picking it up being so close. Another thing to check, make sure everything is grounded really good. All else fails, try buying a ground loop for your RCA wires. Hope this helps!
Jun 17, 2012 | Alpine PDX-5 Car Amp
Alpine amp not working.
possably, did you get it professionally fitted? they have lifetime warranty on install,
Apr 22, 2010 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My amp shuts off with my 12in w6's when i turn up the volume
oh no you need a more powerfull amp i recommend selling the one you have and upgrade to a bigger amp ive had the same problem or if not unbridge your amp so it dosent work the amp to much
Mar 16, 2009 | Jl Audio 12W6 Car Subwoofer
ALPINE PDX 1.1000
Feb 28, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
75 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
