Microsoft Xbox 360 Console Logo
A
Anonymous Posted on Nov 08, 2011
What gb do you need to play a xbox kinnect - Microsoft Xbox 360 Console
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 41 Answers
  • Posted on Nov 08, 2011
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
41
Questions
0
Helped
17991
Points
69
You can play the Kinect on any hard drive size, it comes with the 4GB hard drive though.
Unable to change family sittings on xbox kinnect
Settings need to be changed in the main Xbox 360 settings menu for family settings/parental control
My xbox kinnect sensor keeps saying it is not on a level suface but it is and wont play games what am i to do
Ok either your laser is bad or if it says it's not on a level surfaceyou have to replug it if that doesn't work try cleaning the laser if that doesn't work either the DVD-rom is horrible or you just need to get a new laser
Can i put a kinnect on a old xbox.. have it got to have a certain gb to play it let me no asap ... thank you for ur time
I don't think you can play the Kinect on an old Xbox 360, since the new Xbox comes with it. I'm not completely sure on this matter, but there is no possible way the Kinect can hurt your Xbox 360 since it is just hardware and external.
Xbox kinnect keeps shuting down, less than 5 minutes into loading and/or playing the game.
  • Make sure your kinect is correctly plugged in to your Xbox
  • Make sure your Xbox power cord is plugged in
If problems continue it is because there is a problem with the kinect sensor. Having the kinect automatically turn off has become a common problem for many users. Try returning your sensor to the place of purchase and get a new one. Seeing as it is a known problem the store will likely understand and give you a full refund.
Do you need to be connected to the internet to set up kinnect for the first time
No, it is not absolutely necessary although it is helpful if any updates are available for the Kinect.
-Zach
It wont let me use a knect on my xbox 360
ITS NOT THE XBOX YOU WERE SOLD A FUALTY KINNECT MODULE
My xbox 360 say's it wants an upgrade to make the kinnect work
Conect your xbox to your internet and update it. xbox needs to update every few months to get the new stuff in it.
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
2answers
I just purchased an xbox kinnects bundle. I was doing the set up and it asked if I wanted to update so I said yes. Then the xbox turned off and will not turn back on. Please help!
Yikes...I would check to see if the power plug did not come off the xbox, then check the outlet to see if it's working, I would then remove the xbox kinnects bundle, then turn the xbox to see if its working.Then start allover. Good Luck!!
4answers
XBOX games on XBOX 360
You must have an Xbox 360 Hard Drive to play original Xbox games on your Xbox 360 console.
You can only play approved original Xbox games on Xbox 360. Visit the following Web site to view a current list of approved original Xbox games that you can play on Xbox 360:
http://www.xbox.com/games
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
