Question about HP ProLiant ML370 G4 Server
Attempting to boot from hard drive server 2003
Posted by amupolow on
  • Josiah Dec 11, 2013
    Hi amupolow, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Posted on Jan 11, 2009
Anonymous
  • 173 Answers
SOURCE: Can not install windows server 2003 on Acer Altos G710
Hi! Turn off computer check cable & power cable connection. Windows 2003 Operating System will not support SCSI Drives.
Posted on Apr 08, 2009
ohms
monk3ybidzness
  • 1879 Answers
SOURCE: what to remove server 2003 from hard drive
the server 2008 installation includes the option to format the harddrive
Posted on May 02, 2009
Alan Rothery
  • 109 Answers
SOURCE: new install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
Posted on May 26, 2009
SOURCE: Unable to boot using Windows
Change the OS media or optical drive.
set the boot controller order.
Posted on Nov 29, 2011
DC7600 Wont boot from win 2003 CD
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
Hope this helps
Dec 09, 2012 | HP DC7100 PC Desktop
We have hp server ml370 when i restart the server its stopped on attempting boot from hard drive c and never continue
This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
Oct 21, 2012 | HP ProLiant ML370 G4 Server
Logical drive has been disabled due to possible data loss
Replace the HDD whose led is blinking in AMBER ( orange ) colour.
Mar 11, 2012 | HP Compaq ProLiant DL380 G4 Server
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
Lap top will go any futher than entry screen...
This is a normal set of messages for a computer that is configured to attempt to boot off of a network server. Most home computers and laptops don't normally do this. If you never saw this before, booting from the network is probably the last try the computer makes before giving up. Basicially it is telling you that there is no valid boot device to start the computer from. It used to use your hard drive, but now it cannot because it has been disabled in the BIOS or the hard drive has died. You can check this by hitting the key to enter the BIOS Setup program (generally F10 or Del, it tells you when it is booting up) and making sure that the system does see your hard drive properly in the BIOS and ensuring that it is either first or second in the boot order.
Apr 07, 2009 | Packard Bell Computers & Internet
Gateway 995 boot problems
Maybe you can check you BIOS / your boot device priority and set it to your hard drive as default.
If this doesn't work, then the problem would be your hard drive (it's read / write function is not functioning properly.)
Feb 21, 2009 | Gateway Computers & Internet
Jan 05, 2009 | Dell PowerEdge 1600SC Server
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
HP ProLiant ML370 G4 Server Logo
396 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
