Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Daewoo plasma tv no scart no hdmi what sort of lead going to in the tv
Posted by sohbat ali on
4 Related Answers
mnadi
Modi Elnadi
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
Posted on Aug 25, 2007
Anonymous
  • 59 Answers
SOURCE: whaere is the scart lead?
http://www.e-daewoo.com/products/owners_manual/DTS42(English).pdf
Please have a look at the above user manual from the Daewoo site. You may need to down load the Adobe PDF reader if you can't open the file. You can get that from this web site;-
http://www.adobe.com/products/acrobat/readstep2.html
I am not sure that this is exactly your model but one page of the PDF document , page 14 shows the connections at the back of the TV with no obvious SCART connection. So I think you will have to connect the two using a component video cable and the Left and right audio cables as show in the manual on page 28. or via an s video cable and right and left audio cables as show on page 30.
If the connections in this manual look about right for the connections on the back of the your TV set I would be tempted to take this manual printed out (or just the image of the back of the set page 14) down to your local TV shop with the Freeview box and ask them what cables they recommend you use to connect the set.
Also be aware that cables from these TV shops cost a fortune and you can probably buy the cables cheaper on eBay once you know which ones you need. Without seeing the freview box its hard to know what cable options that box offers you.
Regards
Posted on Aug 14, 2008
Anonymous
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
http://www.avforums.com/forums/6539544-post3094.html
Posted on May 17, 2009
Anonymous
  • 403 Answers
SOURCE: how do i hook up my 42" daewoo plasma tv to coax
your gonna need a converter box to go from coal to r.c.a. plugs. cost about $20. your local hardware store should have it.
Posted on Mar 14, 2011
Got a double picture on my TV which is going through a bt u view box
If you are not getting a tidy pic first thing I would check or change is scart lead make sure they are firmly in back of TV and your viewing box if so try another scart lead, the thicker the scart lead is the better they are apparently. Or if your using hdmi lead instead of scart try another hdmi port at back of TV as these ports tend to break easy in TV as they break off the mother board.
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Is there a step by step process to connecting my panasonic plasma hd tv to my dishnetwork cablebox?
hi does your cable box have hdmi ports if so connect hdmi lead from cable box to to tv hdmi 1, if your tv doesn't have hdmi then connect scart lead from cable box to scart 1 on the tv hope it helps
regards
shaun
2helpful
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
I was using my ps 3 on my plasma tv connected by a HD lead. I then hooked it up to another tv using a scart lead and now it won't work. I hooked it back up to the plasma tv and it works fine. I need it to...
Got to settings in the PS3 Crossbar and go to display settings. The first one should say video output settings, click on it. It should say your connection type is HDMI. Select component/D Terminal and hit change. The screen should go blank. During this time plug it in to your other t.v by the scart. It should say "Can you read this screen?" hit yes and there you go. To go back to HDMI do the same.
What is the TV channel set to to play a dvds151 dvd player?
almost all Dvd players are connected to a television by either a scart or a HDMI lead.
When you plug the scart into the back of your television (make sure its in properly) then turn the power on. on your dvd player.
This should automatically come on as scart leads send a voltage up the scart telling the tv to change to that source/av.
If it is connected via a HDMI cable then if you look at the back of your telly it will tell you what HDMI input number it is. then all you have to do is press the AV/ SOURCE button on your remote to select that number.
Hope this Helps
Little Dish Fitter
Whaere is the scart lead?
Regards
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Top Daewoo Televison & Video Experts
David Shaub
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
