Question about Scubapro MK25/G250 Hp Regulator
Loud noise on my MK25 scubapro regulator when I connect it to a 200 bar cylinder
Posted by Marven Lanojan on
Dan Jacobs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
Balanced regulators make noise on initial pressurization
Posted on May 16, 2014
1 Related Answer
Anonymous
SOURCE: Extreme loud sound on MK/25
did you check your bulletins from scuba pro ? depending on the actual year of mfg ( you can call scuba pro and give them serial number )
there was a retro fit kit made for the mk 25 first stage of you send me your email i will send the bulletin to you
other wise if you wew working from an earlier service guuide then you would notbe aware of the retro fit kits and pistons some of the earlier schematic will not show you that o ring that you were refering to
Posted on Aug 28, 2009
Strange noise from mk17
Scuba pro has repair facilities everywhere they can fix this problem with a annual service kit.
Feb 26, 2013 | Scubapro MK17/S555 Regulator
I have been using my A700/mk25 for six month and recently it has been making a whislting noise when I inhale.
the whistle noise is some thing loose (torn o-ring) inside the second stage. this is covered under warranty. scuba pro offers a parts for life program which is no cost to you if 1st & 2nd stage with a computer are bought at one time. just pay service labor. the whistle noise will be repaired are replaced free under 1 year.
Dec 23, 2012 | Scubapro Mk25 & A700 High End Regulator By...
Schematics for a scubapro mk17 regulator
these are controlled by scubapro due to they need specail testing equipment to repair regulators E..G now IP pressure is 135 psi and there is no adjusting screw shims and springs then the cracking effort test to see if you have pressure flutter or creep. these can not be seen with out testing equipment.
Mar 18, 2012 | Scubapro Scuba Diving & Snorkeling
"yearly Maintenencae" what is
thay clean and change the o-ring the needly seat and new diaphram its some thing that you do every year to certifi for ins. purposes
Apr 23, 2011 | Scubapro MK25/G250 Hp Regulator
Service
You will need to contact your nearest Scubapro authorised dealer. You can look up your nearest dealer from the main scubapro website. Most Scuba shops that undestake servicing will be able to sort this for you as scubapro is a worldwide brand.
Oct 03, 2010 | Scubapro MK2 Plus/R295 Regulator
Anyone know where I can get a Scubapro repair guide for the R295?
check here: http://www.frogkick.dk/manuals/scubapro/Manuals/
Jan 16, 2010 | Scubapro MK2 Plus/R295 Regulator
My problem is i don't have anymore teeth in my mouth i can not bite the regulator if i dive, my regulator will detached to my mouth and i can not proceed with my work as underwater assistment.
They sell aftermarket mouth pieces that you warm in water once soft and pliable you bite down it takes shape to your bite plate which is further back in your mouth and can not be pulled out .
Dec 04, 2009 | Scubapro MK25/G250 Hp Regulator
With inhalation there seemed to be a brief stop in the air stream and some resistance. This happens regardless of how my second stage is tuned. I have had two other divers to try it and they both felt it...
Is this reg new by any chance??
Or perchance it's due a good service?? Sounds like something is sticking inside..
Alternately, I had a similar problem with my mk25 just after I bought it. The dive center I was in were able to fix it overnight for me so I the weekend wouldn't be a washout and the said afterwards that the problem was one of the seals/valves inside that was a bit of a design flaw. They knew about it and had replacements on hand so it could be worth letting your local service center look at it and see what they think..
It's possible this is it too..
Sep 27, 2009 | Scubapro MK17/X650 Regulator SCUBA...
Jan 21, 2009 | Scubapro MK25/G250 Hp Regulator
Scubapro MK25/G250 Hp Regulator Logo
453 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
