Question about Whirlpool Duet GHW9150P Front Load Washer
Drum knock when spin cycle - Whirlpool Duet GHW9150P Front Load Washer
Posted by sandra tracy on
jalal
    Habit-Forming:
  • 178 Answers
Check the drum dampers
Posted on May 11, 2015
Oloyede Monsuru
    Genius:
  • 1,417 Answers
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Posted on Nov 09, 2011
  • Lorenzo Lynn
    Lorenzo Lynn May 04, 2014
    Another thing to check is the shocks, sometimes they are broken. Also check the shipping bolts on the back. They usually have a yellow or red tag
Ftf530es knocks during spin cycle
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
Spin cycle make noise
from what you wrote the signs are that the bearings have gone
Dec 17, 2013 | Indesit W 123 Front Load Washer
Whirlpool Duet WFW9200SQ has knocking sound located under drum under or near motor. Knocks during spin up and down cycle and on last highest spin.
the problem is a cracked spindle on the back of the drum. It most likely also tore up the grey plastic front shield.The only thing to do is throw the machine out sine the drum cost parts onle is over $400 for drum, and over $400 for the front plastic.l
Nov 12, 2009 | Whirlpool GHW9200L Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Sep 18, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
873 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
