Hello there Gary and welcome to FIXYA
Usually
when an oven won't bake properly or stops baking , it's because the bake igniter is weak or
burned out. The igniter is a small, round or rectangular device, that's
about 1 inch by 4 to 8 inches. It's near the burner itself.
The
burner is the tube-type device the gas flows through before it's
ignited. It has many small holes on the sides to let the gas, when
ignited, form a long, low flame. If the igniter is weak, if it glows red
but doesn't get hot enough, or if it's burned out, the gas doesn't flow
to the burner and the burner won't ignite. If this is the problem, you
may need to replace either the igniter or the gas safety valve. Usually
the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
