My phone shows this message "Please Wait......" No dial tone can't answer phone.
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
SOURCE: GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
SOURCE: 2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
SOURCE: Phone Not Working
I have had the same problem before and now again for the last week...I finally remembered what I did last time to solve it!
I put my "unavailable" Handset into the main cradle and left it there for a slow count of 20. That has reset the unavailable handset and returned the dial tone etc.
Maddening isnt' it!
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
