Question about Samsung - Laptop R480 / Intel Pentium Processor / 14" Display / 4GB Memory / 320GB Hard Drive / BLUR... (36725723504) PC Notebook
The screen continuoulsy scrolls on word, internet, ppt, anyting. How do I get it to stop? I will by typing in a word document and use backspace or enter key or delete and the side bar will scroll quickly to the bottom of the page or end of text. I cannot get back up to the top of the document unless I press ESC. this is a temporary fix. This also occurs on all web pages, ppt, anything I am viewing will also scroll to the bottom of the page. Please help!! It is constant.
Posted by Michelle Van Der Wal on
A Hoffman
    Master:
  • Samsung Master
  • 313 Answers
The Page Down key or the Down Arrow key is stuck on the keyboard, or the laptop thinks so.
Try cleaning the keyboard with compressed air and a gentle vacuum. DO NO USE WD-40 or similar.
If that doesn't work, try an external keyboard plugged into a USB slot. You may have to disconnect the keyboard ribbon connector first, if it does not recognize the external keyboard.
Posted on Nov 01, 2017
4 Related Answers
Anonymous
  • 118 Answers
SOURCE: my scroll feature on the touch pad on my alienware
I've seen this before and I think I know what might have happened.
Of course, I'm guessing, so bear with me.
during an update from Windows website, the touchpad drivers were updated. This was done, in all likelihood, without your knowledge.
Find the touchpad in the Device manager (I'm guessing you know your way around a computer) and look at the properties.
Then, roll back the driver and restart.
good luck.
tony
Posted on May 19, 2009
Crankstart
Chris
  • 696 Answers
SOURCE: Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
mardoo6
Matthew Kubin
  • 162 Answers
SOURCE: I have just purchased a
Try to update you graphic drivers and adjust the solution
Posted on Mar 02, 2011
Gamr13
  • 70 Answers
SOURCE: 0xc00000e9 problem? please help
you will have to do a re-install or insert a (windows 7/8) cd and repair my computer and select an option
Posted on Jun 11, 2012
How do i fix ppt file? Please help
Hello. There are different methods available to recover corrupted PowerPoint files.
Open presentation in MS Word document
and follow this steps:
- Open MS Word.
- Click on Open button of File menu.
- Select Files of type box and navigate to your corrupt file, Open it.
Also you can try Recovery Toolbox for PowerPoint https://powerpoint.recoverytoolbox.com/
More information see here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/677-how-to-recover-powerpoint-file
Feb 05, 2015 | Microsoft PowerPoint for PC
My tablet does not switch ON
Do a complete hardware reset, search goolge how to hardware reset your tablet.
Dec 10, 2014 | Archos 101G9 Android Internet Tablet
SEARCH GOOGLE USING E-SPEAKING
These commands are built-in. You do not have to add or program them.
Working with Applications
Say... Open Word
Open Excel
Open Email
Open Powerpoint
Open Internet
Open Notepad
Close Application
Close Window
Close Document
Scroll Down
Scroll Up
Start Word
Start Excel
Start Email
Start Powerpoint
Start Internet
Start Notepad
Minimize
Maximize
Scroll Left
Scroll Right
Browsing the Web
Browse the web using the following commands: Open Internet
Google Website
Yahoo Website
Altavista Website
MSN Website
eBay Website
e-Speaking Website
Go Back
Go Forward
Refresh
Dialog Commands
Sometimes a program will simply ask you for a yes or no answer to an alert box or dialog. Yes
No
Cancel
Affirmative
System Commands
You can control when e-Speaking is "listening" to you using these voice commands. Standby
Resume
Stop Listening
Begin Listening
Hello
Computer
Listen to Me
Add a New Command
Add Mouse Click
Moving the Mouse
The Mouse Movement option has to be checked on the Mouse menu. Mouse Left
Mouse Right
Mouse Down
Mouse Up
Faster
Slower
Stop
Mouse Clock One
Mouse Clock Two
Mouse Clock Three
Mouse Clock Four
Mouse Clock Five
Mouse Clock Six
Mouse Clock Seven
Mouse Clock Eight
Mouse Clock Nine
Mouse Clock Ten
Mouse Clock Eleven
Mouse Clock Twelve
Slide Left
Slide Right
Slide Down
Slide Up
Mouse Buttons
Select
Double Click
Right Click
Properties
Drag Item
Drag File
Drag Object
Release Item
Release File
Release Object
Mouse Jump To
Mouse One - Top of Window
Mouse Two
Mouse Three
Mouse Four - Middle of Window
Mouse Five
Mouse Six
Mouse Seven - Bottom of Window
Mouse Alpha - Left of Window
Mouse Beta
Mouse Charlie
Mouse Delta - Middle of Window
Mouse Echo
Mouse Foxtrot
Mouse Golf - Right of Window
Editing Commands
Doing some word processing? These commands may help perform common Windows functions. Select All
Edit Copy
Edit Paste
Edit Undo
Edit Delete
Edit Find
Delete Line
Find
Search and Replace
Moving the Text Cursor
These commands may help navigate documents. Left Arrow
Left One
Left Two
Down Arrow
Down One
Down Two
Right Arrow
Right One
Right Two
Up Arrow
Up One
Up Two
Page Up
Page Down
Beginning of Line
End of Line
Beginning of Document
End of Document
Simulating Keys
Enter Key
Home Key
End Key
Spacebar
Escape Key
Delete Key
Backspace Key
Tab Key
Dictation
Start Dictation
Stop Dictation
Standby
Resume
Train Word
Show Commands
Dictation - Editing
Delete that Phrase
Delete that Text
Delete Last Phrase
Delete Last Text
Strike that Phrase
Delete Last Word
Edit Copy
Edit Paste
New Line (inserts a line)
Next Line (inserts a line)
New Paragraph (inserts 2 lines)
Next Paragraph (inserts 2 lines)
Select All
Delete Key
Backspace Key
Reading Commands
Read All Text
Read Selected Text
Stop Reading
Pause Reading
Resume Reading
Skip Ahead
Skip Back
Read Faster
Read Slower
Phonetic Alphabet
You must really like using voice if you are into the Phonetic Alphabet. Alpha
Bravo
Charlie
Delta
Echo
Foxtrot
Golf
Hotel
India
Juliet
Kilo
Lima
Mike
November
Oscar
Papa
Quebec
Romeo
Sierra
Tango
Uniform
Victor
Whiskey
Xray
Yankee
Zulu
Feb 05, 2011 | e-Speaking
Character keys won't work within microsoft Works document
One possibility that occurs to me is the text is the same color as the background. I have had this happen to me several times. Type something (even though you cannot see it) and highlight the area, and then change the text color.
Oct 27, 2017 | Microsoft Works 8 Full Version Mini Box...
Need a users manual
Hello, You will get the reference guide for your Symbol PPT 8800 scanner in the following link. http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5809304apdf&sliceId=&dialogID=108884644&stateId=1%200%20108882281 Hope it helps, Good luck! ~regards, Jegan
Jun 03, 2009 | Symbol PPT 8800 Wireless Barcode Scanner
Cannot download adobe, (or any) files and get following message:
The problem lies in the Temporary Internet Files folder. Sometimes the index.dat file can become damaged.
If this occurs, you'll have to delete the index.dat file and restart your computer.
Then you'll be able to download files correctly again.
Follow the steps below to delete this file.
1) Open Internet Explorer.
2) Click on Tools, Click on Internet Options
3) On the General tab under Temporary Internet Files, click on Delete Files
4) Click Ok when it asks if you want to delete the files
5) Under the History section on the General tab, click Clear History, then click Ok
6) Close Internet Explorer
7) Log off the current user and Log onto another user account such as Administrator
8) Click on Start, Run
9) Type CMD and Press Enter to open a command prompt
10) Change directories to the Temporary Internet Files directory by typing the following command,
(substituting the correct drive letter and the word username with the correct userName).
cd drive:\Documents and Settings\username\Local Settings\Temporary Internet Files\Content.IE5
Example: cd c:\Documents and Settings\Mark\Local Settings\Temporary Internet Files\Content.IE5
11) type del index.dat and press Enter
12) Type Exit and press Enter to close the command prompt
13) Restart your computer
Once the computer has been restarted, open a web page with a link to a download.
Click on the link and download the file. It should now work.
Please take time to rate this fixya
May 11, 2009 | Internet Compaq Evo N600C Laptop
Samsung - Laptop R480 / Intel Pentium Processor / 14" Display / 4GB Memory / 320GB Hard Drive / BLUR... (36725723504) PC Notebook Logo
63 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
