British Telecom Freestyle 2200 Trio Cordless Phone Logo
Question about British Telecom Freestyle 2200 Trio Cordless Phone
How to reset pin code to bt freestyle 750 phone
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: BT Freestyle 750 is working but although the
Just restart your BT and try to access it again or else try to access your B.T within the range of your phone.
Posted on Apr 11, 2011
Anonymous
SOURCE: My BT Freestyle 2200 became de-registered from base.
My solution, bought a new phone.
Posted on Nov 15, 2008
terryr2009
  • 9 Answers
SOURCE: BT freestyle 2200 cordless phone
try this link
http://btsupport.custhelp.com/cgi-bin/btsupport.cfg/php/enduser/fattach_adp.php?p_sid=0&p_tbl=9&p_id=11816&p_faqid=11816&p_created=1219079325
Posted on Mar 19, 2009
Anonymous
  • 50 Answers
SOURCE: cant unlock my keypad on freestyle 750 phone
Press and hold the Lock key to unlock. Stupid BT did NOT provide this info in the instruction manual!!!
websitesfreeway
Posted on Nov 11, 2009
Anonymous
SOURCE: instructions foe bt freestyle 350
How do I set up caller number display on the Freestyle 350?
I wish to see who is calling my number.
Posted on Mar 04, 2010
Have acquired an additional handset with charger. The screen flahes a 'Please register' message. How do I do this?
Assuming you do not have 5 handsets already, make sure that the new handset is fully charged. Carry it over to the base and press Find on the base unit. (This sends out a signal to the handset.) On the handset, press Menu and use the Up arrow to go to the line marked Settings. Press Menu to access this sub-menu. The line H/Settings should be highlighted. If it isn't highlighted, use the Up/Down arrows to navigate to this line. Press Menu to access this menu. Use the Up/Down arrows to navigate to the line Register. Press Menu again. Use the Up/Down arrows to select the base to which you want the handset to be registered. Press Menu again to confirm that base registration. Enter the system PIN for this base; the initial PIN is mentioned in the manual on page 35 and on page 54. Wait for the handset to indicate that it has been registered; it will say Registering until the process is finished. If you take too long to do the steps at the handset, the signal will stop and you will need to start over.
If you already have 5 handsets, you will need to de-register one of them. If the registration process does not properly occur and the issue wasn't taking too long, either the base or the handset is not communicating properly. If other handsets work, I'd suspect that the new handset is faulty.
BT Systems has the manual on the Freestyle 750 product site: http://btbusiness.custhelp.com/app/answers/detail/a_id/12103/~/bt-freestyle-750-user-guide . The direct link to the manual is http://btbusiness.custhelp.com/ci/fattach/get/223683/1232386209/redirect/1/filename/BT_Freestyle_750_user_guide.pdf . The procedure to register the handset is on pages 53-54 of the manual.
I hope this helps.
1helpful
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
How can I get new batteries
Normally in the BT range the batteries are rechargable, hence the base charger, so do not use ordinary batteries. If the phones are not charging, go to boots or tesco and buy AAA rechargeables 2 per handset. Once replaced allow at least 6 hours charge before use. After that just carry on as normal.
BT Freestyle 7250
karnatka sim idea mo no 8746828196 this is mo no this mobil no puk code pzzzzzzzzzzz
I have forgotton pin no on my bt freestyle 350 can I reset without losing phone nos stored
I reset my phone but lost numbers and doesnt help with pin. Still cant find a way of overriding old pin.
BT Freestyle 750 is working but although the screen is bright nothing appears on it
User Manual required for BT freestyle 750 telephone
http://www.shop.bt.com/content/uni2/documentation/56xm/userguide.pdf
Click on the above, hope it helps.
Dec 25, 2009 • Cell Phones
36helpful
2answers
Cant unlock my keypad on freestyle 750 phone
websitesfreeway
Top British Telecom Lands Phones Experts
NADARK
NADARK
Lawrence Oravetz
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
