Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
Can not connect to Configure D-Link DAP-1522 I Can not for the life of me connect to my DAP-1522. I need to connect to it on my PC so I can connect it to my Wireless Router/Modem so I can use it as a wireless bridge. Both 192.168.0.50 & DLINKAP Links do not work I just get a connection timed out error. I have changed my IPV4 Alternate Configuration to: IP Adress: 192.168.0.10 Subnet Mask: 255.255.255.0 Default Gateway: 192.168.0.50 I have also connected the DAP-1522 to my PC Via LAN cable and turned off all firewalls. It just wont connect..
Posted by James B on
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: Wireless router problems
your computer is only connected to the signal coming from the router that's why it's saying connected but it seems that your router is not properly configured to provide internet access since your dns server is the same as your default gaetway. it could be that the your router is not in sync with the modem.
- if it's working before, tyr to power cycle everything by turning all the devices off then turn on the modem first, wait for all the lights on the modem to turn on then power on the router and the computer.
- if the router is for initial setup, kindly provide me you ISP, brand and model of the modem and how you connect the modem to the router and tell me if how you access the internet directly from the modem.
Posted on Jul 02, 2008
Anonymous
  • 241 Answers
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
Posted on May 28, 2009
Anonymous
SOURCE: dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Posted on Aug 31, 2009
Anonymous
SOURCE: Cannot connect to Dlink DAP-1522 at 192.168.0.50.
HOLY $hit !!!!! This worked!!!!
I've wasted a whole day trying to figure this out (... and I'm fairly good at computers, but this was a 8itch).
This works for Windows 7 (64-bit version, updated as of March 21, 2011).
DLink DAP-1522 Xtreme N Duo
Part Number: CAP1522ACA...A1
Hardware ver.: A1
Firmware ver.: 1.21
IP Address: 192.168.0.50
Follow the instructions mentioned above to the T.
The following information maybe long-winded but I hope some of this additional info helps others who are having a SON-OF-A-8ITCH, like I did.
I've also disabled the wireless adapter on my laptop. You don't need Wireless connection, since you will be using the network cable (mostly the BLUE cable (CAT5), maybe a different color too, still trying to look for pink, hehehe).
YES, you MUST connect your computer to the DLink DAP-1522 using the network cable. Use any port on the back of the DLink DAP-1522 and to your laptop/computer.
My Network Settings had two Internet TCP/IP Protocol's (ver4 and ver6). I made the changes to the ver4 TCP/IP Protocol (and NOT the ver6).
I also unchecked several of the other items, which only left the following CHECKED:
\' client for MS networks
\' QoS packet scheduler
\' File and printer sharing for MS networks
\' Internet protocol version 4 (TCIP/IPver4)
...... sorry for the \' above. This is my symbol for a "check mark."
NOTES:
Not sure if this matters... but these are some of the things I've also done....
- the switch on the back of my DLink DAP-1522 is set to "BRIDGE."
- I didn't need to push the button on the top of the DLink DAP-1522.
- My Windows Network connection is a "public network" (with no internet).
- Windows Firewall is ON.
- I did not flash to a newer version of Firmware (still have 1.21).
You will notice the network icon in the tray has a yellow <!> but don't worry because we know there is no Internet access, all we want is just a link connection to the DLink DAP-1522 Bridge so we can get into the web-based GUI of the DLink SAP-1522 Bridge, and play.
Once you gain access to the DLink DAP-1522 built-in Web Browser, by opening Internet Explorer and typing the address 192.168.0.50 you will be shown the Log-In page.
User Name: admin
Password: - (no password, keep blank)
Chris (from Canada, eh)
Posted on Mar 22, 2011
SOURCE: I just got a dap-1360
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password :
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Posted on Mar 24, 2011
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
Jul 12, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1320 cant connect on internet
You posted your question in December 2013.
Do you still need an answer?
Dec 16, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
Mar 09, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
Dap-1522 setup wizard
You can download the latest version of the firmware you need below. Just determine if you have dap-1522 or dap-1522 rev.B.
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. Example picture on the bottom of this page.
latest dap-1522 firmware:
ftp://ftp.dlink.com/Multimedia/dap1522/Firmware/dap1522_firmware_141b.bin
latest dap-1522 revB firmware:
ftp://ftp.dlink.com/Wireless/dap1522_revB/Firmware/dap1522_revB_FW_203b.bin
Install instructions for the firmware are on page 41 in this pdf:
ftp://ftp.dlink.com/Multimedia/dap1522/Manual/dap1522_manual_130.zip
Here is a great setup video for it:
http://www.youtube.com/watch?v=lYJPGqtyFZU
Jun 05, 2012 | Computers & Internet
DAP-1522 WIZARD
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. See the example picture on the bottom of this page.
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
Apr 04, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Dlink dap 1522
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
244 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
