Question about Humminbird 788ci Color Fishfinder Combo with Internal GPS without Transducer 4074301CHO 4074301CHO ()
Gps wont work but fishfinder works fine
When i do a system's test it says the gps unconnected
Posted by andrew cho on
Marc D.
    Scholar:
  • 111 Answers
This model has two versions, one with the GPS as an external piece, and one with the GPS mounted internally. If the location of the internal mounted GPS cannot get a clear shot at the satellites overhead, it will tell you it cannot get a GPS fix. If it says it is disconnected, you may have a problem with the internal GPS. There are external GPS pucks available for this unit. Here is a helpful website.
http://www.humminbird.com/leading_innovation/fishing-systems.aspx
Posted on Nov 07, 2011
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
Lowrance hds 5
I would imagine it might have something to do with water turbulance? Do you have a sensor thats located at the bottom of the boat somewhere? In my grandpas boat, the sensor is at the rear bottom near the hole where you can drain the water, if your going very fast it doesnt work very well, slow or stopped and it works fine. If you have that type of sensor make sure whatever holds it is tight so the sensor cant move around.
either that or you got some funky wiring issue lol
Nov 01, 2013 | Lowrance Hds-5 GPS Receiver
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
How do u put the gps locations in the Eagle Fishmark 500c Color Fishfinder
Hi, no good news I'm sorry. It's a fish finder not a combo fish finder/gps so you are unable to enter co-ordinates. Sorry Phil.
Sep 22, 2011 | Eagle Fishmark 500c Color Fishfinder
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
Wont search for sattelites
Hi
Does your unit have an external aerial as shown in the pic, If so double check the connection from the aerial into back of the fishfinder, lube with water proof grease (Non-conductive)
You do not say whether it has worked before.
Also need to know where it is located on boat, it must have a view of sky overhead (If internal antennae)
Ext antennae must also be in view of sky, not under "solid" cover.
Aug 12, 2009 | Garmin GPSMAP 178C GPS Receiver
Garmin gps 498.
I think the transducer is down too low. Raise it up so that the center of it is in line with the bottom of the boat.
Jun 02, 2009 | Garmin GPSMAP 498 Fishfinder /...
Garmin gps 498.
I have the same exact problem, but i don't have a solution
Mar 24, 2009 | Garmin GPSMAP 498 Fishfinder /...
GPS/Fishfinder keeps dropping and restarting
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Jan 27, 2009 | Simrad Ap1601r Elect Only Ap16 Rc36 Rf300...
Humminbird 788ci Color Fishfinder Combo with Internal GPS without Transducer  4074301CHO 4074301CHO () Logo
627 people viewed this question
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
