Question about i-mate PDA2k Pocket PC
SOURCE: Can't reset
Do a hard reset take the battery out leave it for sometimes may be 15 20 minutes and then put the battery in and turn on it should work fine
Posted on May 23, 2008
SOURCE: screen
Open the Back Cover.. remove the Battery, Simcard, Memory Card and then leave it open for 1 minute.
Put the battery back, start your device then if you get the same message you need to update the firmware...
In the worst scenarios, your Siemens SX66 has a corrupt ROM and need to be fixed as in "Hardware"... which can be done by a Siemes expert.
Good Luck
Posted on May 24, 2008
SOURCE: can't hard reset
Take the battery off. hold the power for 10 sec. Then put the battery back on. Push the reset button 1st then hold the power for 6sec. let off the power button 1st and it should do A hard restart. Take out any memory cards before you do this.
Posted on Sep 08, 2008
SOURCE: my pda2k is stuck to booting in normal mode
remove first the SD card before booting, see if your unit successfully booted up.
try to replace battery, if battery is faulty it will not turn on successfully.
Posted on Feb 08, 2011
Feb 08, 2011 | i-mate PDA2k Pocket PC
May 06, 2010 | i-mate PDA2k Pocket PC
Nov 01, 2009 | i-mate PDA2k Pocket PC
Sep 05, 2009 | i-mate PDA2k Pocket PC
Oct 06, 2008 | i-mate PDA2k Pocket PC
Dec 22, 2007 | i-mate PDA2k Pocket PC
Sep 21, 2007 | i-mate PDA2k Pocket PC
Aug 11, 2007 | i-mate PDA2k Pocket PC
Apr 26, 2007 | i-mate PDA2k Pocket PC
Oct 17, 2012 | i-mate PDA2k Pocket PC
Mar 12, 2017 | i-mate PDA2k Pocket PC
101 people viewed this question
