Hi, After few minuits of using sound (especially mp3, mobile). it dissapear. I still can use sound via fm transmiter and jack, but no longer via internal/integrated speaker. PLEASE DON'T ASK ME ABOUT SETTINGS LIKE MUTE, VOLUME LEVEL, ETC.!!! I have open tomtom, but I didn't find any damage (on speaker, speaker wire, connector, main pcb). Any ideas, please???
SOURCE: TomTom 520 - no sound
are you sure the sound is not on mute - this can be changed in the preferences section, also make sure the volume is up
SOURCE: tom tom one v1 Loose power connector
If the problem exists both when you use the vehicle power connector and the usb cable to your computer, then you have to assume that the problem is with the socket on the One. If it's still in warranty, I would send it back to Tom Tom for repair. Contact customer support for repair information.
The link is as follows:
www.tomtom.com
SOURCE: tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
SOURCE: Hands free calling and FM transmitter
Old post, but here we go.
1: Update to latest firmware from tomtom, for Gox20/x30 that is 8.351
2: Make an silent mp3 file and put that onto device
3: Play silent mp3 in loop
4: Send nav instructions over fm to radio... et voila!
