Question about KitchenAid KGSA906PSS Gas Kitchen Range
Error code F2EO - KitchenAid KGSA906PSS Gas Kitchen Range
Posted by Marie Bunn on
Gene Meier
  • 2,341 Answers
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Posted on Nov 06, 2011
Randall Williams
    New Friend:
  • 3 Answers
F2EO... I solved this by 1.Unplug range ,2 remove control knobs for the range top coil ellements 3. unscrew plastic caps that are behind control knobs that hold glass facia in place 4. carefully remove glass facia 5. clean the circuit board on the backside of the glass facia ,I used windex and a soft cloth ,as well as a q tip so as not to damage any part of the circuit board , 6 replace all parts ,glass facia ,plastic caps ,knobs, plug stove in and give it a try , if this fails ,you may require a new touch pad , if it works ,call me when the turkey is done ,I won't be late , good luck
Posted on Nov 22, 2012
Kitchen aid stove has error code-f2EO how to solve that error?
Keypad issue. I would try disconnecting ribbon that connects keypad to main board. If that doesn’t solve problem after reconnecting ribbon, then keypad would most likely need replacing
Oct 01, 2018 | Kitchen Ranges
How can I unlock the door on my whirlpool oven showing a code of F2EO ?
Possible Solutions
Reset power to the product:
There may be a problem with the User Interface or Keypad, the Control, or the associated wiring.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Jun 06, 2018 | Whirlpool Ovens
I have a maytag wall oven it shows error code f2eo what does this mean and how do I fix it?
E0 F2 is usually a stuck key on the keypad. You will need to replace your keypad most likely. It's possible to be caused by the control board also. If it is NLA we can rebuild it for you at fixyourboard.com
Aug 13, 2015 | Maytag Ovens
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | KitchenAid Kitchen Ranges
I am getting an error code f2eo and it is saying stuck key. No button will work.
Error code f2e0 means the touchpad is bad. Give me the part number, or go to ApplianceTimers.com, we may be able to repair it.
Mar 20, 2011 | Kitchen Ranges
Have error message F2EO,oven not working
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
Nov 21, 2010 | KitchenAid KESC307 Electric Kitchen Range
Range flashing code f2eo
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Dec 13, 2008 | Kitchen Ranges
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
KitchenAid KGSA906PSS Gas Kitchen Range Logo
908 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
