RCA F32648 32" TV Logo
Anonymous Posted on Nov 06, 2011
Went black and white rca f32648
Now playing in black and white dvd wii but all menu all setting are in color is there a reset or something
Anonymous
Level 2:
Novelist:
  • Expert 123 Answers
  • Posted on Nov 08, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
123
Questions
0
Helped
27053
Points
193
So far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
MY onn dvd player is showing black and white
Check your warranty. Call for support.
*** The following is for information only.***
* If your player and TV set was working prior to this then it's probably playing a black and white movie or the TV color setting is off and needs to be reset.
* For TV go to menu, Picture, Color set up. (Best to restore to factory settings as a starting point.)
* For DVD try a known "color' movie (at least something later than 1965) if it plays in color then the older disk is B&W.
* If someone pulled out the cable (Yellow, Red, and White) this is the Video (Yellow) and Audio Left-White, Audio Right-Red.
* Check this cord for damage and reconnect into corisponding color coded jacks. Note; this cord will not affect the "color of the set other than not show up at all - Blank screen if wrong plug inserted.
* Call TV support line (or DVD support) for advice.
Aloha, ukeboy57
4answers
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
2answers
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
1helpful
Wii menu and all sports in black and white; how do we get color?
You are probably plugged into the wrong RCA slot for your Wii's configuration. If your TV is an HDTV you need to either go to your Wii's settings and change the TV settings to HD or remove the Wii RCA (Red/Yellow/White) from the HD slot and put them in the standard input RCA slot. Red/Yellow/White insted of Red/Green/White.
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
No color on my TV!
You should plug the Wii into the AV1 or 2 on the LCD TV and make sure that the RCA plugs are pushed in all the way. Also make sure that you have the plugs properly inserted into the back of the Wii. If all is connected verify the settings on the TV's menue and make sure that they are all correct. You may also want to verify the settings on the Wii menu.
Wii gone bad?
check your connection to the tv. are you using the rca jacks? is the rca input on tv "loose"?
Color went out
what do I need to do to get the color back on my t.v.>>
get rid of boy friend! problem fixed!
sorry i just could not resist!
doesn't this set have Auto color balance resets individual picture tube guns (red, green, blue) to maintain consistent overall picture quality for the life of the tube.
RCA RC5215P DVD Player only plays in black & white
Dear brother at first u insert a original copy righted disk and check .And there is an option for swithing in menu for PAL and NTSC.And also please check ur TV is supported NTSC3.15 colour system,If not check ur player in a multi system TV.
Dear brother if u r a technician please can u mail me the IC number of IC104 in signal board under the lense mechanism in the same RCA RC5215P DVD player,becouse I have missed this IC from my player
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
