Dryers Logo
Question about Dryers
LG front load dryer timer jumps from 40 min to 19 min then to 5 minutes, all within a few minutes. This was supposed to be fixed by Sears 4 months ago and now it's happening again.
Posted by Tara Dancy on
5 Related Answers
BigJay462
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
Anonymous
  • 1073 Answers
SOURCE: Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
Posted on May 08, 2008
Anonymous
  • 105 Answers
SOURCE: just stopped working
If it is a gas dryer you could plug something else, like a lamp into the outlet to test it. If it is electric then you need a multimetr or a voltage tester to see if you are getting 120 to each leg and 240 across the hot legs. There isn't any easier way (:
Posted on Apr 08, 2009
Anonymous
SOURCE: drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Posted on Dec 29, 2008
Anonymous
  • 10865 Answers
SOURCE: Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
LG front load dryer jumps from 40 min to 19 min to 5 min in short time. Any suggestions?
Dryers can base their drying time two different ways. If you are using the "dryness" settings, when you first start the cycle, the timer will show a specific time. If the contents dry fairly fast, the moisture sensors in the dryer will reduce the remaining drying time. This may be what is causing your changes. If you want a specific time on the dryer, or the dryness settings aren't getting the clothes as dry as you'd like, opt for a "timed" dryer setting, where you choose the drying time. This bypasses the sensors.
1helpful
2answers
Why does my LG WM1814CW's timer get stuck during cycles, A 28 Min cycle will take 45 Min.
It could likely be that this is during a fill portion of the wash or rinse cycle, and the water inlet is restricted not allowed the full flow into the tub. If this is the case, check both ends of the hose connections for a plugged / restricted filter. run some water into a container with hose off to purge any additional minerals from the intake.
3helpful
The dryer will not turn off and it is only 6 months old. The timer will not move from its setting and runs continuously. Dryer setting does not matter.
The timer switch is bad. It is an easy fix. Simply unplug the power source. Unscrew the 4 to 6 screws from the insturment panel. The knob should pull off from the front. unplug the plug from the switch. Take it to sears parts department and order a new one. The part should not be over 35.00. Installation is the opposite of removal.
Constant mildew smell from washer
Visit this site and read this article:
http://homemanagement.suite101.com/article.cfm/washing_machine_odors
Assuming the drainage isn't a big issue, the vinegar trick seems to work best...you may have to do it more than once if it's really bad.
Jumps time on timed cycles- for example: High dry is 40 minutes time goes down to 36 minutes and then is jumps down to 23 minutes. Once it goes down some it might jump back up during the 20's then it goes...
Replace the timer, this is very easy. Un plug, remove access panel in the back and un plug the timer. This will be connected right behind the knob. It will be screwed down in front as well. Call your local dealership and get replacement part.
Kenmore (sears) oasis washer stops with 36 minutes left
The timer is failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3helpful
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
1helpful
2answers
Drying timer on auto dry
Dec 28, 2008 • LG Dryers
3helpful
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Open Questions:
0answers
Lg dryer DLG1701W te1 and te2 codes blower thermostat keeps blowing as well Hello my lg dryer model number DLG1701W has been having issues for the past 3 days. Dryer finished a normal cycle and wouldn't start up again after swapping load of laundry out. When I tried starting it up again it was throwing a te1 code. Looked up the code on lg's website and tried doing a hard reset. Tried a few more times again and this time I was getting a te1 and a te2 code. Looked up the te2 code and decided to pull the machine out and inspect/clean the exhaust. Exhaust wasn't clean but air flow also wasn't restricted and the flaps on the outside of the house were on and in good shape. Hook the machine back up again and tried starting it again with attempting to reset again with no luck. I decided to pull the machine apart and test the thermistor with my fluke meter. found the thermistor on the exhaust side was reading but was all over the place. 13 ohms while in the machine. Down to 9 ohms when removed. After letting the thermistor sit for a little bit it was reading 11 ohms but was all over the place in that range between 11.08 to 11.96. Wasn't sure if that was normal or not so I decided to replace it. Tested the other thermostats while I was in there and found both thermostats on the gas range were reading normal but the thermostat on the exhaust side of the unit was faulty. Not reading at all. So I replaced the thermistor and the thermostat on the exhaust side. Button the machine back up and go to test but initally the same error codes were coming up te1 and te2. Finally after a few more attempts the dryer started. I had it set on a high temp 40 minute cycle. After about 10 minutes of it running though the barrel stopping turning and the gas range shut off. But it didn't throw any codes. The display continued to countdown and all the other light were working as if it was still running. Shut it off a few times and tried starting it back up and the same thing would happen. Countdown would display and countdown. All the lights would light up as if it was working but the barrel wasn't turning. And the gas range wasn't running. I walked away for a little bit to think about it (approximately 2 hours) when I came back to it, the machine was doing the same exact thing as what it would initially do. Click and display a te1 or a te2 code. I pulled the machine back apart again and currently still have it apart. The thermistor seems to be in a continuous 11.25 ohms range with the ohms dropping when touching the sensor it self. The thermostat that was just replaced has blown once again. Any insight on why this could be happening would be very much appreciated Update. Checked all the components again including the motor. Motor checked out good. Put everything back together again. Try it again a few times. This time everytime I tried it, the machine would start and run for a 4 to 5 seconds then shutdown and throw back the te1 and te2 code. Note: it never has both the te1 and te2 code at the same time. Each time it's tried it 1 or the other
Top Dryers Experts
Marvin
Marvin
David Shaub
