Question about HP Compaq Presario CQ50-110US Laptop
What's your problem?It's stuck on logging off
Posted by Vicky L. Sousa on
  • Vicky L. Sousa Nov 05, 2011
    I have unplugged it and let it rest for a few days, so I powered on today and it's still stuck on "logging off", how can I fix this????
Avishek Samaddar
  • 639 Answers
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
Posted on Nov 07, 2011
  • 5 more comments
  • Vicky L. Sousa Nov 08, 2011
    I tried the task manager, but it wouldn't come up, it still is "Logging off".
  • Avishek Samaddar
    Avishek Samaddar Nov 08, 2011
    Which Operating System are you using?
    Operating system is Vista 32 bit
  • Avishek Samaddar
    If you can log into Windows Vista, then you should follow these steps.
    1. Close and save any documents that you may have open.
    2. Click on the Start button to open your Start Menu. The Start button looks like this:
    3. When the Start Menu opens click on the All Programs menu option.
    4. Click once on the Accessories Start Menu group.
    5. Click once on the System Tools Start Menu group.
    6. Click once on the System Restore icon. After you click on the icon, if a User Account Control window opens you should click on the Continue button.
    You will now be at the System Restore screen. From this screen you can specify the restore point that you would like to restore.
    By default, Vista will already have selected the Recommended restore option. This restore point is one was made after a new program, driver, or update was installed. If you would like to use this restore point, you can click on the Next button to start the restore process. On the other hand, if there is a more recent restore point that you would like to restore you should select Choose a different restore point and press the Next button. This will bring you to a screen that contains a listing of all the available restore points that you can restore to.
    You should select the restore point that you would like to restore and press the Next button to start the restore process. Vista will display a Window showing your selected restore point and asking you to confirm that this is the one you would like to restore.
    If you would like to select a different restore point press the Back button. Otherwise you can press the Cancel button to exit System Restore or the Finish button to begin the restore process. If you selected Finish, Vista will display a second prompt asking you to confirm that you would like to continue the restore.
    If you are sure you want to do the restore, and then press the Yes button. Vista will now log you off of the computer and start the System Restore process.
    When the restore has been completed, you computer will be restarted and when Vista boots back up it will be restored to its previous state. When you log in to Vista for the first time after the restore, you will see a message showing that the restore was successful.
  • Avishek Samaddar
    There are more steps also after this and I am not able to post such long text. Thus if you feel confusing please come for a live chat / email conversation if possible.
    I cannot get off the screen that says Logging Off. When it runs out of battery, then I start up and for a second or 2 the windows screen comes on, then it's switches back to Logging off again. Is there an F# that I can push to get to the command screen???
  • joecoolvette
    joecoolvette Nov 27, 2011
    W-H-A-T does THE above have to do with a computer STUCK in the logging off mode?
    Really! If you Do Not know, DON'T provide a 'Solution'.
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html if you wanna back to stock rom
or this http://www.droidvan.com/2013/03/cm-9-final-for-galaxy-gio.html if you wanna taste off ICS on your phone
Mar 12, 2013 | Cell Phones
Windows Log-On Lockout
If you can get access to another pc you can download Hirens Boot CD it's free, then burn it to a disk and boot from it. there is a password removal program on it and it's pretty easy to use.
If you do use it and you get stuck you can get in touch with me at [email protected] and I'll explain how to do it.
Nov 08, 2012 | Computers & Internet
Can't access user log in page or system restore
i think no other way rather than reinstalling your operating system because you already tried all the methods to repair the windows
while on stuck press ctrl+alt+del to open up task manager if it opens we can try to solve the problem otherwise reinstall it
Post me again
Jun 08, 2012 | Microsoft Windows XP Home Edition with...
My laptop has been stuck on the 'logging off'
restart your computer while the screen is black restarting you will see on it a certain key to press to enter set up press and hold that key to enter set up (BIOS) using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
if you need more help with this post a reply
hope this helps you
Sep 21, 2011 | Samsung RV510A01 T4500 23G 4GB 320GBDVD...
My laptop is password locked, and this morning I tried logging on with my password and it says that it's not correct. I tried all the capslock and capitalization errors and it still isn't...
Are you sure a keyboard key isn't stuck? Try checking whether the shift or capslock keys have become stuck, also consider the possibility that someone could have changed your password. If that doesn't help, you should try this software. Use another windows PC capable of burning CDs.
Jul 05, 2011 | Dell Inspiron Mini 10 Notebook
I CANT LOG IN AND IT ASKD ME TO TYPE IN A CODE THAT SHOWS UP SO IT WILL LET ME LOG IN AND IS STILL NOT WORKN IT KEEPS GIVING ME DIFFERENT CODES TO USE AS PASSWORDS I KEEP TYPING THEM AND WONT ALLOW ME TO...
I have to assume you mean logging into a web site of some kind.
The 'code' that you type in IS NOT THE PROBLEM. That is only to prove you are human and not a computer trying to access the site.
The Problem is the log in info you are using. The Log In NAME and PASSWORD need to be correct. The extra funny looking info [code] is not the log in info, just human proof.
You may need to follow a link for 'Forgotten Password' or 'Log in name' to help you log in.
Hope this helps.
May 20, 2011 | Computers & Internet
I forgot my Birthday and can't log in Facebook
If you're stuck out of Facebook, and need to log in, you can reset your password by clicking on "Forgot your password?" located under your password input box. Once there, you can answer one of three questions to retrieve your password. So, if you have forgotten your birthday, there are other things that you're able to remember instead, like what your email is, or a name of another friend.
May 06, 2011 | Facebook Social Network
HP Compaq Presario CQ50-110US Laptop Logo
116 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
