Question about Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
How to change the clock on hotpoint bd35 double oven
Posted by James McInerney on
4 Related Answers
Anonymous
  • 12 Answers
SOURCE: how do you set clock on hotpoint bu62 double oven
electronic clock I presume. first of all turn power off then back on. Clock display will now be flashing.
press and hold the two buttons far left and hold in. at the same time press the + or - button to set clock. You should also have a pan icon between the hours and minutes iluminated which means you are in manual mode
Posted on Oct 22, 2009
Anonymous
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
Anonymous
SOURCE: clock on cooker flashing
Excellent! Now my clock works, but where can I get an instruction booklet for this oven? Thanks.
Posted on Jun 10, 2009
Anonymous
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
Why will my hotpoint double oven will not turn on how do I reset the clock?
check breaker and plugs ---if good and still have no power to controls turn off breaker for a few minutes and turn back on if still no power to control-- damage to an internal circuit which will require a repair person to diagnose
Sep 21, 2016 | Hotpoint Ovens
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Oct 22, 2017 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
How do you set clock on hotpoint bu62 double oven
Oct 21, 2009 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint UY46 Style Line Stainless Steel Electric Double Oven Logo
406 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
