Once you have selected the right router, you will feel ease in your profession as well as home. Cisco Router customer facing some time problem with this router so we are providing more service for the customer help, which is one of CISCO Router Customer Service Numberthere are just dial toll-free number 1-833-283-8333 and get instant solution.
https://servicenumber.org/cisco.html
For most cisco routers there may be an option under "access restrictions" in routers interface called "Website blocking by URL address"
To access the routers administrative interface, open up a web browser and type in the address 192.168.1.1 (by default unless previously modified) Cisco Router Price Buy Cisco Routers 3Anetwork com
SOURCE: cisco 871w router
Is this router brand new sound like it could be a bad router. The wan port could be going bad. I have had similar problem like this before and took days for me to figure out.
SOURCE: CANT ACCRS WIRELESS ROUTER WRT110 BY LINKSYS CISCO
Sounds like the router needs to be reset..
Before you do a reset try to login to the router by typing 192.168.1.1 in the webrowser ..
If that fails then look on the back or under the router and there is a reset button. Press and hold for 10 sec ... The let sit for a min or 2 then try logging into it..
Note: That the router will have to be setup again. Default login admin for the password .. don't enter any usernames
SOURCE: we use cisco 1811 as router and firewall when try
Is this problem solved or you are still eperiencing this issue?
SOURCE: I tried to deny access to the facebook &
Try the reset button again until it resets. If that doesn't work then you might try unplugging it and leaving it unplugged for a while and hope it looses it's memory. Eventually it should reset using one of those methods.
Also next time instead of trying to block facebook and youtube thru the whole network try blocking it for one particular pc instead, which does require that you used assign ip addresses instead of dhcp but allows that kind of control.
You could also have administrator privledges on the kids machines where they login with user name. Then go under IE and block the sites there.
SOURCE: i want to block facebook
192.168.1.254 or 172.16.0.1 are the ip addreses you have to type into your browser while your computer is connected (wired prefered) to your router. Once the login comes up you need to type in username and password which are...2wire (username) with blank password OR Wireless (password) with blank username... You can make your changes from there... if you have any further questions let me know....
LIke this if it helped you !!!!! Please!
