Question about HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop
Says missing file root>\system32\hal.dll - HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop
Posted by Daniel on
nancy green
    New Friend:
  • 11 Answers
Sometimes we look for the difficult when the solution is right in front of you.
I got the error message after flashing my AMD64 BIOS. Tried rebooting, then a repair, and the problem wouldn't go away. But, if I set the boot sequence up for CDROM first, then HDD, and let the bootup go WITHOUT hitting any key to boot from the CD, Windows would start.
Tried the randall's solution. No luck. Tried copying Hal.dll to system32 still no luck.
Then by accident, I hit F8 during the initial boot. I selected my master 1 and got through.
Went into setup and found that my HDD boot sequence had my slave as the first boot device. End of probelm.
So, here is what was going on. I had upgraded to a larger hard drive, and kept the original as a slave. (Just to have access to files that I might have forgotten about. While I had erased the files on D, I didn't remove the system files. So, when I tried to boot, it was the system on D drive that would try to boot but all the necessary files needed to boot that disk had been removed.
But, randall's solution link is a good one to know. It helped me solve a similiar probelm on another computer where I had two operation systems to choose from, but only one installed.
Posted on Nov 16, 2011
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 29, 2010 | Computers & Internet
How to solve this problem <windows root>\system32\hal.dll.
Hi
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
1.Insert and boot from your WindowsXP CD.
2.At the first R=Repair option, press the R key
3.Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4.Type bootcfg /list to show the current entries in the BOOT.INI file
5.Type bootcfg /rebuild to repair it
6 Take out the CD ROM and type exit
OR
Better solution: This seems to always work
expand x:\i386\hal.dl_ y:\windows\system32\ X= cd rom drive letter
Thanks and Regards Aboobacker S
Sep 23, 2010 | Microsoft Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Missing file or corrupt in system32 hal.dll
Dear User,
Try to download the hal.dll file from here.
http://www.dll-files.com/dllindex/dll-files.shtml?hal
You will get one popup download the file after donwloading you have to unzip to c:\windows\system32 folder.
Mar 03, 2010 | E-Machines eMachines Desktop PC
Systemroot/32 /hal.dll missing
You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
Nov 15, 2009 | Computers & Internet
Missing windows root system32\hal.dll
Hi
There are few different ways that the "missing or corrupt hal.dll" error may present itself, with the first listing being the most common
Use the following links
http://www.computerhope.com/issues/ch000490.htm
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
Note: if the repair is not successful then you would have to redo the entire OS. This would mean data loss on the computer.
Thanks for using Fixya
proton
Aug 15, 2009 | Acer Aspire One PC Notebook
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows error ... \system32\hal.dll. Please re-install a copy of the above file!
Use the recovery disks that came with your computer to do a repair installation. Put the disk in your cd / and or dvd rom, restart computer and select repair installation from the prompt.
May 02, 2009 | Computers & Internet
\system32\hal.dll. MISSING FILE
YOU NEED TO DOWN LOAD THIS PROGRAM FROM MICROSOFT.
WWW.WINDRIVERS.COM/HAL.DLL
OR
WWW.WINDRIVERS.COM/SYSTEM32/HAL.DLL
ONLINE ADDRESS BAR: WINDOW DRIVERS FOR SYSTEM32\HAL.DLL
OR FIND THE FILE IN THE ORIGINAL SOFTWARE YOU INSTALLED THE WINDOWS VERSION ONTO THE SYSTEM
ROD
Feb 12, 2009 | Acer Aspire 5000 Notebook
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop Logo
79 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
