If you have not bought it yet some dealers may have them already set up.Cobra is a popular radio so before you buy ask. you could just match it up to a cobra 25 mic though.
it depends on what radio if you have a cobra 18wx style or maxon's, or a radioshack type the red is constant power 12v, orange is a switched 12v.. IE key like a stereo, and black is ground. if you have a 25 or 29 ltd types or exports they only have 2 wires red 12v and black ground. but you do find some power cords that have all three, and the orange on the 25 / exports are not used.
do you have a spectrum analyzer? A function generator , bird 43 watt meter,multimeter etc. ? If you have all these then go to www.cbtricks.com and get the information you need .
to be sure that u dont burn yr radio try to check yr swr with an external meter to be mounted between the radio and the antenna and check if it works! good luck.
rgds stefano
the mics on these cobras have a receive wire in them so the transmit will still work even if the receive wire is broken,if this wire is broken the unit will not make any sound...........remove the plug from the radio end of the mic and check the connections on the 5 pin connector.....(could be a cold solder or broken wire) or try a new mic or one that is proven work on another radio hope this helps.................good luck!
