Question about Sharp FO 3800M All-In-One Laser Printer
My sharp fo 3800 is flashing E 7 and wont respond to anything els. What does this code mean and how do i stop it?
Posted by Fether on
2 Related Answers
Anonymous
  • 27 Answers
SOURCE: my printer is a Canon S500 and it wont print anything
Here is the owners manual : http://gdlp01.c-wss.com/gds/0900005491/S500usersguide_us.pdf
Try page 144 I believe that is what you are describing.
Posted on Jun 22, 2009
Anonymous
  • 3085 Answers
SOURCE: We are getting a 634 error code for a Sharp Fax
receiving machine is always BUSY
Posted on Jun 24, 2009
WHAT DOES ERROR CODES F 5-02 AND E 7-11 MEAN
both deal with the scanner located under the big glass. F-5 is bright light that comes on when you make a copy or the reader located under the glass that see the original, the E7 deals with shading of the original again under the glass get a tech to check out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 18, 2015 | Sharp Fo 2080 Monochrome Laser
The power light on my 46 inch sharp aquos LC-46D64U WONT STOP FLASHING AND WONT TURN ON
The flashing is a diagnostic code. Write down the sequence of short and long flashes and contact the service number if you are still under warranty. If not then you'll need to do further research on the meaning of the code via internet searching. Your owners manual will also have some information on the blinking that may be helpful.
Feb 11, 2015 | Sharp Aquos Televison & Video
HOw to change FSE code on Sharp Advanced D.A.L. EL-531X
To change the FSE code on your SHARP calculator press SETUP and choose 0. FIX means that it shows you all the decimal places. SCI is scientific notation, ENG changes the scientific notation in groups of 3's. NORM1 and NORM2 are your normal number ranges, however norm2 starts from zero and anything negative will be written in scientific notation.
Jun 02, 2014 | Sharp Office Equipment & Supplies
Our office uses a Sharp FO-4470 fax machine. this morning it is flashing an error on the display of High Voltage Error. Can anyone help with this?
It probably means that the high voltage driver board is blown. You'll have to take it to a service center for repair.
Feb 18, 2011 | Sharp FO-4400 Fax
When adding on My Sharp EL-1701C calculator it will stop adding and show a P. E
The P stands for power & usually means you need to change your battery
Dec 22, 2010 | Sharp EL-1701C Calculator
Sharp FO DC535 fax will not come to ready
Turn on the fax while holding down the stop a start key, don't let go until you see 1 =all ,2=image , 3=none. Press 2 for image. If the problem persist press 1 for all.
Dec 29, 2008 | Sharp FO-DC535 Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
FO 2850 - Power Outage Aftermath
Unplug the machine for 4 hours & then plug back in. If you get the same symptoms, it will be cheaper to replace with a new one. Power supply is probably blown.
Jul 01, 2007 | Sharp FO 2950 Plain Paper Laser Fax
Sharp FO 3800M All-In-One Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
