O2 Samsung SGH-E250 Cellular Phone Logo
Yulchen Posted on Nov 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wanna decrease the sound for ring tone - O2 Samsung SGH-E250 Cellular Phone
damneddle
Level 3:
President:
  • Master 1,607 Answers
  • Posted on Nov 03, 2011
damneddle
Master
Level 3:
President:
Answers
1607
Questions
Helped
336522
Points
4892
Hello Yulia,
Go to Settings, Sound Settings, Incoming Call and adjust the volume from there.
I hope this helped you.
My sidekick lx text alert tone does not work. the sidekick does not vibrate or make a sound when i receive a text.
This most likely has to do with the sound profile that you currently have set. Go into the sound options, see if there is a detailed option available to increase/decrease the ring volume or vibration.
Some phones have the option to turn on an alert and vibration for text/incoming call.s
May 02, 2011 • Cell Phones
3answers
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 • Nokia 2600
If i want to enter ringing tone and to select the phone will off and restart
hi there!
the phone goes off and restarts by itself when you try to choose/set a ring tone? its possible that the ring tone file is missing or corrupted. or if that ringtone came with the cellphone when you bought it, try removing the battery for a minute, put it back in, turn on the cellphone and see if the same issue happens, you may wanna have the cellphone look onto by a technician because its already a hardware issue i believe =)
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
42helpful
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
2helpful
2answers
Ring volume too low
All you need to do is goto Tools and Settings/Sound Settings/Ringer Volume
Sony ericsson w300i sound problems
menu/settings/sounds and alert...then you can increase the volume or decrease it
1helpful
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
Ringer Help
Hi there, don't worry changing ring tone it's a very easy task. All you have to do is go to the main menu on your phone. From there you wanna go to settings, and you should see and option there to change the ringtone. In the other hand if your phone has sound files that can be used as a ring tone, then all you have to is go to the location of that file (it's usually located under "my stuff" "my music" etc) and select the file, from there you can select that file to assign as a ring tone. If you need further instructions you might want to put the make and model of your phone. Good luck!
Top O2 Cell Phones Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Muhammad Irshad...
Muhammad Irshad...
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
