Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset Logo
bas basha Posted on Nov 03, 2011
I have Sanleford YB 500a safe, I lost the code, any way of opening it???? thanks
Chris core
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 14, 2012
Chris core
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1149
Points
5
Yes contact a locksmith. They will in turn contact the safe support people that they use. They will give the locksmith a code to open your safe.
Open a yb-500a sandelford safe
I Personally don't think that these should be sold as "safes", but that is a discussion for another thread
I have the keys of my safewell but I forgot the combination.. How can I open it? Help me plz. The model is YB-350A
There is no such thing as a general code to open safes. So the only thing you can do is write down all codes you ever used, and try thm one by one. Sorry, but if there was any "backdoor" in a safe, the code should be useless.
Looking for cheats for gutair hero 3 i would like the codes to unlock everything on gutiar hero 3
Goto Main Menu > Options > Cheats > Enter Cheat in game. Use the following codes ( R - Red, G - Green, O - Orange, B - Blue, Y - Yellow ), without strumming.
Unlock everything (no audio will play when entering this code)[GRBO] [GRYB] [GRYO] [GBYO] [GRYB] [RYBO] [GRYB] [GYBO] [GRYB] [GRYO] [GRYO] [GRYB] [GRYO]Unlocks All SongsYO,RB,RO,GB,RY,YO,RY,RB,GY,GY,YB,YB,YO,YO,YB,Y,R,RY,R,Y,O
Codes pulled from Gamefaqs. They're an awesome website for game cheats, reviews, walkthroughs, etc.
Have fun!
2helpful
3answers
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Phone lifter not working. light on top of base not lit up
Try re-pairing the headset to the Plantronics 500A base unit, it sounds like the headset may have lost connection with the base. Here is the link for the pairing instructions:
Plantronics 500A Pairing Instructions
Good luck from Headsets Direct!
1helpful
Headset not working. red light on base is flashing and yellow light is static; no blue light
It sounds like the headset may have lost connection with the base, try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
I lost my sentry safe code! what can i do to program the safe! can i do it without the code? please help! thanks
Depending on model, some safes have a key override that can be used to open the safe. Most models do not. Without a key override, probably the only thing you can do is to contact a lock smith, otherwise, start checking each possible code combination until you find the correct code.
If there are valuables in the safe, then take it to a locksmith. Otherwise, it might be cheaper to get another safe.
6helpful
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
21helpful
2answers
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
