Electronics - Others Logo
Posted on Nov 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting my wii to my home theater
I have a problem, I have connected my nintendo wii to my home theater but the only way that I have been able to get a picture is by connecting it to the video in on my projector. I have the projector connected to the component video out to my A/V receiver. Is there a better way to connect my gaming system to my home theater?
kiranbodapothula
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 46 Answers
  • Posted on Nov 09, 2017
kiranbodapothula
Expert
Level 2:
New Friend:
Night Owl:
Answers
46
Questions
0
Helped
20718
Points
243
  1. Connect your set-top box HDMI output to the Xbox One HDMI input.
  2. Connect the Xbox One HDMI output to your A/V HDMI input.
  3. Connect your A/V HDMI output to the HDMI input on your TV.
  4. Notes
  5. This option requires that all devices support audio over HDMI.
  6. Surround sound from your set-top box will not be passed through the Xbox One.
  7. When you perform this kind of basic setup with an A/V receiver, you're passing both audio and video through another device. Depending on your equipment, there's a small risk of audio or video lag.
  8. Connect your set-top box HDMI output to the Xbox One HDMI input.
  9. Connect the Xbox One HDMI output to the HDMI input on your TV.
  10. Connect the audio output from the TV to the audio input on the sound bar using either HDMI or optical S/PDIF cables.
connecting my wii to my home theater - cannon-vgxymk2tgdawonehfad1wklu-4-0.png
1 Related Answer
sentra07
  • Posted on Dec 29, 2009
SOURCE: How can i connect Nintendo wii to avr-590. Have
To connect a Nintendo Wii to an AVR-590, I am assuming this is a Denon Receiver, you will need to connect the Nintendo Wii to the TV, then connect audio out from the TV to the AVR-590 Receiver, and select the receiver to be in Pro Logic. Depending on the TV, if you have fiberoptic output on the TV, you would hook a fiberoptic out from the TV to the AV Receiver, but you will still not get true Dolby Digital, just Dolby Pro Logic. This will be the most effective way to solve the problem. Hope This Helps
Geek Squad
Tried to set netflix on my wii and an error code came up 50299
Hey, here are your options:
  • Power cycle your home network and perform a connection test on the Wii.
    If your Wii was previously connected online, and no changes have been made to your home network, perform the following steps (if you have not previously connected your system online, skip to the next bullet point):
    1. Remove the power from your wireless modem and router. Plug the power back into both devices, starting with the modem.
    2. From the Wii Menu, select "Wii" in the lower-left corner, and then select "Wii Settings." Use the arrow on the right to move to the second page, then select "Internet," followed by "Connection Settings." Last, select your connection file, and the select "Connection test."
  • Create a new connection file.
  • Set up a new connection file making sure the Wii is attempting to connect to the appropriate wireless network and is receiving a strong wireless signal. How to Wirelessly Connect the Wii to the Internet Nintendo Support
    - Matt
2helpful
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
We want to connect to internet but how do you do that?
To connect your wii to the internet you will need wireless router in your home. Then follow the official nintendo wii wifi connection guide to get connect through your access point: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Regards,
Omeil
16helpful
How do i connect a nintento wii to my sony home theatre system model htsf 470?
Hi beejaysaunde,
To connect your Wii to the htsf 470:
1. Connect your Wii to your TV.
2. Use a separate audio cable (red/white) and connect from your TV to your htsf 470.
3. Choose the correct selection on the htsf 470.
This setup will have your Wii's video go directly to your TV and the Wii's audio to be sent to the stsf470.
I hope this helps.
4helpful
2answers
Wii sing it microphone has a huge audio delay
there should be a setting in the menu that allows you to change the option for this. like "delay" or "calibration"
I dont know how to connect the wii to my rx-465 receiver.
The Wii AV cable should have a red/white pair of Audio Output jacks on it.
Check out pg. 8 of the Wii manual: http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Connect the red/white RCA plugs from the AV cable to a line level audio input on your receiver. If you use AUX IN, then select AUX IN on the INPUT selector switch. You should then hear the sound from the Wii through your receiver/home theater system.
I can't figure out how to hook up a wii to a home theater system
On the back of your AVR (audio video receiver) where you connect a DVD, VCR or any other component. Example if there are open component jacks where you would connect a VCR just plug in the Yellow, Red and White cables. Turn your AVR to the source you connected to and turn on the TV. It should then play thru the speakers and be seen on the TV. Treat it just like a DVD player or any input source.
Video inputs
I had the same problem until I switched my player-to-TV connection from S-Video to Composite.  Then it worked just fine.  Now I have player-to-TV as Composite, and Wii-to-player as Composite connected to Aux1.
Can i send video from Nintendo Wii through my home theater to my projector?
A few things to consider; what type of connection is your Wii using? Composite, component, s-video, coax? Most home theater setups are made to route multiple video signals, usually of the Composite (RCA Red Yellow White) variety, and should be clearly labeled Video In. If it doesn't have extra inputs, you might want to consider buying a media switchbox- http://www.cyberguys.com/templates/searchdetail.asp?sk=MC71730&productID=7663 A switch like the one linked above allows you to hook multiple audio and video sources into it and easily switch between them by pressing a button on the front.
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
